I have three relatively new portable oxygen tanks. One about two years old, the other two purchased this year. I've been noticing that they have been losing pressure at around 200 psi/month. So I put one of them upside down in the sink today and find it slowly bubbling where the gauge screws into the tank. The sealant used looks like regular white ptfe tape. I think it'll be easier to fix this myself than go through the hassle of shipping the 3 tanks back to the vendor.
Normally with plumbing work, I have little success with ptfe tape and prefer a pipe dope product. Looking on Amazon, I find two products for oxygen, one a green ptfe tape and one a thread sealant:
http://www.amazon.com/gp/product/B00LB1TWBK/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=A11OKIK916253R#productDetails+
http://www.amazon.com/gp/product/B008HPW242/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Before I go forward, I thought I'd check in with the brain trust here on any recommendations.
Thanks, Larry
I've never used anything on oxygen threads at work. Just make sure they are CLEAN and GREASE FREE! Unless you enjoy spontaneous combustion.
Same experience as Hank...
No ptfe on these type of fittings...
House plumbing, yes.
Anyone use Teflon on O2 fittings?
The fitting for the gauge is standard tapered pipe thread. It's not the same as the CGA540 fitting between the valve and the regulator. I don't see how this thread can seal without some sort of sealant.
And yes, it will be clean and using a oxygen-specific sealant when I put it back together.
Thanks, Larry
Tapered thread, yes...
Sorry couldn't come up with the term.
In that case, there is probably a standard of how much to use and the proper direction to wrap it to go with a torque setting.
Make sure there isn't any excess that likes to cover or go down the hole.
I would have expected ferules and slightly higher tech type fittings.
I should have started with... 'I don't use O2, yet...'
When I had my steel O2  bottle hydro tested they replaced the fitting using PTFE tape ! So I would use teflon tape on the gauge.
BILL
post-8267-0-70257300-1414452182_thumb.jp
BILL
In looking at the picture of your pressure gauge I see the same recommendation "use No oil". Does any one have a Mil spec for " No oil"?
Despite having many apprentices look, we can't find the spec.
I may be misunderstanding your question, but "no oil" is "nothing with a petroleum base". ie. nothing that will burn. The tiniest bit of combustible material with a healthy dose of pure oxygen will make a terrible explosion. Any friction, like tightening a fitting can raise the temperature to a point the oil will ignite.
Don,
It's Clarence's northern sense of humor ;)
Don't use..
Vs.
Use no
When mixed..
Funniness ensues.
Being the new/young mechanic in that shop has got to be a learning experience.
MIL-T-27730A covers the tape and specifies that it has nothing in it that will make it combustible or give off dangerous fumes when exposed to heat.  It was replaced with A-A-58092.
Don,
Don't use..
Vs.
Use no
When mixed..
Funniness ensues.
It's very educational. Some of the classics for your enjoyment. Fetch me some shore line for the float plane we're working on, don't forget the compass headings for your compass swing, who left the lid off the prop wash? Now its evaporated! Order more oxygen No oil.
Wait till you are the guy helping with your own annual and under the wing in his shop taking out screws with your bit driver (even with impact to help knock it loose). Apparently some things are not meant to be!
I have not made it past apprentice yet. ;)
Ned Gravel
Lucky steward of C-FSWR, a '65 E model at Rockcliffe, Ontario, (CYRO)
Used to send new flight attendants to the rear lav with an air sick bag to get an air sample for maintenance before we landed.
Ah yes, off to stores for a tin of tartan paint, a sky hook and a long wait please son
And when they come back 'They're out of tartan paint an skyhooks, but they said they could give me the long wait', send them back and tell them to be sure they get an 8130 for it!
