Sun visors on a '65 C model.
 I installed the LASAR Wiser Visors in Jolie's E a couple of years ago.  These units articulate every which way and are very useful.  Much more useful than the original.   The most difficult part was accurately drilling the holes in the correct location on the plastic post pieces.  This is necessary in order to match the new visor mounting stud.   Get it right the first time!
Link to comment
Share on other sites
Philip,
Did you do the install or did you have a mechanic do them for you?  I'm currently visorless and want to install something to take the place of the originals when the 201 windshield went in.  Where did you get yours from?
Thanks,
Brian
Link to comment
Hi Brian.
Yes, you can install the LASAR visors yourself.  You do have to be very accurate when you mark/drill the mounting stud hole access point through your plastic pieces.  It's a one shot deal.  Otherwise, you have an extra hole that will need to be filled.  Speaking from experience here.
Drpep has posted photos for you of the installed units so that should give you a good sight reference.
Link to comment
  • 5 months later...
  • 4 weeks later...
Check out http://www.rosenvisor.com/aviation/detail.asp?idproduct=64&idCategory=15&idSubCategory=32.  Although I can't promote it because it is non STCd, the small lens (5x12) works great.  Good clear plastic, very adjustable, flips left or right with a single visor install.  Plane is a lot safer knowing I can land into a setting sun without having the glare of not using a visor.
Link to comment
According to Dan @ LASAR, they need enough interested parties to commit to purchasing the visors to run another batch and keep the cost down. LASAR needs about 40-50 orders to release the batch -- not sure how many they already have. I just added myself by completing the order form on their website and adding "add me to the order list" in the comments per Dan's instructions.
If you need visors for pre '68 mooneys -- please join the list so we can them sooner :-) At this point, Dan's best guess was about 3-4 months out. If they get enough orders, they will build them sooner!
LASAR page: http://www.lasar.com/mod-details.asp?id=26
Order page: http://www.lasar.com/parts/
Link to comment
Link to comment
I do love the "stock" look of things and that includes the Mooney visors.  I would however, find myself saying bad things about those little cute Mooney visors as I was flying along wishing there were better at helping to diminish some sunshine on my face.
So, I have carefully stored my stock little Ovation visors for now, and enjoying the utility of the Wiser Visors.   Life is good when flying through the air in a Mooney.
Link to comment
