A few months ago my narco's display has lost it's contrast. I have reviewed the manual on how to adjust the setting in the start up procedure but it has little effect. Other wise the unit functions fine but its very hard to read and I have to input my codes by counting up or down from each selected digit.
Is this something that can be repaired or is the unit toast.
Any one with knowledge I sure could use your input.
Thanks!
Not too but into your conversation but.. I have used Avionics Unlimited  in Conroe TX to fix my Narco AT150 transponder that had very rare and unusual tray alignment problem. I think the guys name was John he knew exactly what the the problem and was able to fix another problem with pre-amp. Cost less the $100  to fix  it and they  bench tested and yellow tagged for me. it was sent back to me reasonably quick. I thought it was very reasonable. I wouldn't hesitate to use them again even know I am up in the Northwest.
You may  want call them first I tried googling  them and google  came up with goofy  results at least on first page.
Avionics Unlimited
10015 Military Dr
Conroe, TX 77303
(936) 788-7333 (866) 703-6388
James
'67M20C
