warrenehc Posted August 14 Report Posted August 14 Hello, I’m looking to find interior plastic side pieces for my Bravo. It’s a 1990 that sat outside for a bit I believe and the interior plastic side pieces are cracked and broken. If anyone has any leads on a used set that would be appreciated.
Paul Thomas Posted August 14 Report Posted August 14 9 minutes ago, warrenehc said: Hello, I’m looking to find interior plastic side pieces for my Bravo. It’s a 1990 that sat outside for a bit I believe and the interior plastic side pieces are cracked and broken. If anyone has any leads on a used set that would be appreciated. Vantage or fix what you have. Is it still ABS plastic for a 1990 interior? IF so, ABS cement is magic to fix cracks... add some cloth and it's like working with epoxy except it's easier (and better since you're effectively welding the existing ABS). Jeager Interior also has a do it yourself guide with ton of great information. I was given a ton of good advice: https://mooneyspace.com/topic/51672-overhead-console-replacement/#comment-920451
Fritz1 Posted August 14 Report Posted August 14 Knots2U has couple of new parts, call Lasar, whatever they do not have they will know where to find, some parts may be worth repairing others are best used as drill templates, ABS gets brittle, rattles and may just crack somewhere else, depends also on how much time you want to spend
adverseyaw Posted August 15 Report Posted August 15 Wisconsin Aviation has the molds for a replacement set that are similar in design to the original ABS but are higher-quality plastic. Jaeger Aviation / Wisconsin Aviation Mooney Spatial Interior Restorati
LANCECASPER Posted August 17 Report Posted August 17 On 8/14/2025 at 12:35 PM, warrenehc said: Hello, I’m looking to find interior plastic side pieces for my Bravo. It’s a 1990 that sat outside for a bit I believe and the interior plastic side pieces are cracked and broken. If anyone has any leads on a used set that would be appreciated. Best advice I have for you is to take the interior pieces out put them in a box and ship them to Hector at Aero Comfort. Even though they are in rough shape they will come back repaired and covered in Ultraleather looking much better than new. 2
Fritz1 Posted August 23 Report Posted August 23 BAS is parting out Bravo with the newer fiberglass interior, unique opportunity to buy all the parts in one shot, cant hurt to call them to see what is still there 1
Jetpilot86 Posted Sunday at 12:58 AM Report Posted Sunday at 12:58 AM On 8/14/2025 at 9:35 AM, warrenehc said: Hello, I’m looking to find interior plastic side pieces for my Bravo. It’s a 1990 that sat outside for a bit I believe and the interior plastic side pieces are cracked and broken. If anyone has any leads on a used set that would be appreciated. Had mine covered in leather. Turned out great!
