Hi gang,
I'm requesting your expertise here in sourcing a part. I bent my door hold and I might need a replacement. If my research is correct, it is part 310118-503 HOLD OPEN ARM. A quick search at LASAR didn't show anything in stock, so I thought I'd try here and give them a call later. Any insight is much appreciated.
Edited by jonhop
  On 1/6/2025 at 11:25 PM, N201MKTurbo said:
I would just straighten that one. And keep it lubed so it doesn’t happen again.
Expand
Funny thing... I had just put lubricant on and was going to cycle the door a few times to spread it.
Edited by jonhop
Expand
bummer. Missed it by that much....
Mine actually did that once. I was able to straighten it in place. It has been fine ever since.
Careful buying used even from a reputable seller like BAS. That unique barrel-shaped bearing may be missing. I just did this a few weeks ago. Removed mine and installed a light weight strut which I read about on earlier threads.
-David
