PeterRus Posted October 30 Report Posted October 30 The taxi/landing lights lenses are "foggy" or "muted" on both wings -- due to the age, methinks. The lights are LEDs, and I'd like to replace the lenses with new ones -- they are available. However, it sounds like the new lenses will need trimming and/or drilling the screw holes. Some sellers offer trimming service if I mail the old lenses. While removing and installing seems to be (a) legal if I do it myself and (b) straightforward I am not sure I have the tools/experience to trim the lenses and drill the holes. I am sure people have done this -- any comments or advice? Quote
EricJ Posted October 30 Report Posted October 30 Drilling polycarbonate or acrylic needs to be done carefully to prevent cracking the piece, but there are some methods that work well to mitigate that risk. YT vids are your friend for this. Trimming can be a little tricky, too. The techniques are not difficult or hard to learn, though. IMHO it is something you can do yourself, but talk to your A&P/IA first since they sign off your annual. Quote
Marc_B Posted October 30 Report Posted October 30 The one benefit of having your A&P do it is that if they crack it, it’s their expense. If you crack it it’s yours. But with right tools and technique it shouldn’t be that difficult. If you can send in your lens, you might reach out to GLAP and that might be a good middle ground. Quote
M20F-1968 Posted October 30 Report Posted October 30 2 hours ago, PeterRus said: The taxi/landing lights lenses are "foggy" or "muted" on both wings -- due to the age, methinks. The lights are LEDs, and I'd like to replace the lenses with new ones -- they are available. However, it sounds like the new lenses will need trimming and/or drilling the screw holes. Some sellers offer trimming service if I mail the old lenses. While removing and installing seems to be (a) legal if I do it myself and (b) straightforward I am not sure I have the tools/experience to trim the lenses and drill the holes. I am sure people have done this -- any comments or advice? Allow about 8 hours to fit both lenses (sounds like yours are wing-mounted lights). You will need a combination disk/belt sander bench-mounted machine - The Harbor Freight version will work. Also get countersinks from Aircraft Tools Co. They have fluteless countersinks that have a single hole in the side. The cutting edge is the single hole. They do not chatter and will safely cut without cracking. Work slowly with the sander to fit the lens in place, with sufficient play. It should not fit tightly. The holes for the screws will also be oversized. The screw heads will use couner-sinked washers. Do not use the aluminum frame. John Breda 2 Quote
Utah20Gflyer Posted October 30 Report Posted October 30 Have you tried polishing the old ones? Normally you can get them to almost new condition with a relatively small amount of work. Maybe an hour or two. I’d at least try before going through the time and expense of replacing them. 4 Quote
M20F-1968 Posted October 30 Report Posted October 30 Also, when done, leave all screws 1 turn loose. Work very slowly with the sander to fit the lenses. The hardest part is to see that the lenses fit the curvature in all aspects of the compound curves without any stresses when fitted in place. John Breda 1 Quote
GeeBee Posted October 30 Report Posted October 30 1 hour ago, M20F-1968 said: Allow about 8 hours to fit both lenses (sounds like yours are wing-mounted lights). You will need a combination disk/belt sander bench-mounted machine - The Harbor Freight version will work. Also get countersinks from Aircraft Tools Co. They have fluteless countersinks that have a single hole in the side. The cutting edge is the single hole. They do not chatter and will safely cut without cracking. Work slowly with the sander to fit the lens in place, with sufficient play. It should not fit tightly. The holes for the screws will also be oversized. The screw heads will use couner-sinked washers. Do not use the aluminum frame. John Breda That's it. The proper tools make all the difference. Do not use standard drill bit or counter sinks. Get the right ones for acrylic. 1 Quote
Schllc Posted October 30 Report Posted October 30 2 hours ago, Utah20Gflyer said: Have you tried polishing the old ones? Normally you can get them to almost new condition with a relatively small amount of work. Maybe an hour or two. I’d at least try before going through the time and expense of replacing them. You can buy a $35 kit from auto zone, take them off the plane and stuff a towel inside the curve to support the plexiglass and use a buffer or drill. If you wan to super glue some cracks do it before polishing. It only took me about an hour and they looked brand new. 1 Quote
PeterRus Posted October 30 Author Report Posted October 30 Great idea to polish the old ones! Thanks. Quote
gevertex Posted October 30 Report Posted October 30 3 hours ago, Utah20Gflyer said: Have you tried polishing the old ones? Normally you can get them to almost new condition with a relatively small amount of work. Maybe an hour or two. I’d at least try before going through the time and expense of replacing them. +1 to this. I used headlight lens restorer on mine and it got 80% of the yellowing out. Quote
LANCECASPER Posted October 30 Report Posted October 30 7 hours ago, PeterRus said: The taxi/landing lights lenses are "foggy" or "muted" on both wings -- due to the age, methinks. The lights are LEDs, and I'd like to replace the lenses with new ones -- they are available. However, it sounds like the new lenses will need trimming and/or drilling the screw holes. Some sellers offer trimming service if I mail the old lenses. While removing and installing seems to be (a) legal if I do it myself and (b) straightforward I am not sure I have the tools/experience to trim the lenses and drill the holes. I am sure people have done this -- any comments or advice? Great Lakes Aero will trim, as you mentioned, and sell you the correct drill bit. I also highly recommend using tinnerman washers. Also on newer Mooneys they eliminated the metal pieces that go on top of the acrylic. It looks much better without them when the lenses are trimmed nicely. Quote
Utah20Gflyer Posted October 30 Report Posted October 30 I have used premade kits to refinish plexiglass/polycarbonate and they work fine, but you can also do it with 1000 grit wet sand paper, then wet 2000 grit, then polishing compound like you’d use are a car. Don’t do swirls, straight lines. Lots of water when sanding. The good thing about a landing light lense is that it doesn’t have to be perfect like a windshield. You just want maximum light transmission and for it to look good from a couple feet away. 3 Quote
PT20J Posted October 31 Report Posted October 31 I replaced mine. Great Lakes Aero made them for Mooney. They are polycarbonate (aka Lexan), not acrylic. Polycarbonate is softer and more impact and crack resistant but I find it harder to work with than acrylic. Because it is soft, it doesn't polish out as well as acrylic, but you cannot hurt anything by trying. I trimmed mine and it was a lot of work. If I were to do it again, I'd send the originals to Great Lakes and have them trim and drill them. If you drill them yourself, a step drill works best. I deleted the trim piece on mine as the later models. If you do this, drill the holes oversize and use countersink washers. No need to countersink the plastic. 1 Quote
dkkim73 Posted October 31 Report Posted October 31 7 hours ago, Schllc said: You can buy a $35 kit from auto zone, take them off the plane and stuff a towel inside the curve to support the plexiglass and use a buffer or drill. If you wan to super glue some cracks do it before polishing. It only took me about an hour and they looked brand new. Did you use the rotary pads the same way as with car or other applications? Circular polishing and moving it around? I'm thinking of the admonition to polish linearly when doing things by hand like windshields. I got the Novus kit and was going to try doing the ice light (with masking) but thinking the landing light as well (or instead). Quote
Schllc Posted October 31 Report Posted October 31 18 hours ago, dkkim73 said: Did you use the rotary pads the same way as with car or other applications? Circular polishing and moving it around? I'm thinking of the admonition to polish linearly when doing things by hand like windshields. I got the Novus kit and was going to try doing the ice light (with masking) but thinking the landing light as well (or instead). I used a drill and the provided pads for all but the final step. I used a variable speed buffer for that step. They came out great. I was able to get the yellow out completely. They looked new from 5’ away. There were a few spider cracks around the screws they I glued but couldn’t hide. The ice light was a little harder bc it was recessed lower than the skins and I didn’t want to damage the finish on the lip of the painted skin so I taped and did that by hand. That one wasn’t as clear, but I got the yellow out and you couldn’t tell because the light refractor is directly below the lens. 2 Quote
Utah20Gflyer Posted October 31 Report Posted October 31 12 hours ago, dkkim73 said: Did you use the rotary pads the same way as with car or other applications? Circular polishing and moving it around? I'm thinking of the admonition to polish linearly when doing things by hand like windshields. I got the Novus kit and was going to try doing the ice light (with masking) but thinking the landing light as well (or instead). If you are just using the buffing compound then it probably doesn’t matter whether you use straight lines or swirls, but wet sanding with sandpaper I’d recommend straight lines because it reduces the likelihood of swirls being visible later in the process (ie it reduces the total amount of work) The upside of sandpaper is it removes material faster, downside is it removes more material. In my estimation the plexiglass or polycarbonate will need to be replaced because of cracking before I run into an issue with material thickness. If the damage is minor I would probably just use buffing compound, more serious I think the sandpaper makes sense. Quote
Jetpilot86 Posted November 1 Report Posted November 1 On 10/30/2024 at 11:25 AM, PeterRus said: The taxi/landing lights lenses are "foggy" or "muted" on both wings -- due to the age, methinks. The lights are LEDs, and I'd like to replace the lenses with new ones -- they are available. However, it sounds like the new lenses will need trimming and/or drilling the screw holes. Some sellers offer trimming service if I mail the old lenses. While removing and installing seems to be (a) legal if I do it myself and (b) straightforward I am not sure I have the tools/experience to trim the lenses and drill the holes. I am sure people have done this -- any comments or advice? I got mine from Great Lakes and had Maxwell install them at my annual. 1 Quote
dkkim73 Posted November 1 Report Posted November 1 On 10/31/2024 at 1:23 AM, Schllc said: I used a drill and the provided pads for all but the final step. I used a variable speed buffer for that step. They came out great. I was able to get the yellow out completely. They looked new from 5’ away. There were a few spider cracks around the screws they I glued but couldn’t hide. The ice light was a little harder bc it was recessed lower than the skins and I didn’t want to damage the finish on the lip of the painted skin so I taped and did that by hand. That one wasn’t as clear, but I got the yellow out and you couldn’t tell because the light refractor is directly below the lens. That is super helpful, thanks Ray! Is the removal/replacement as simple as it looks? I'll check the MM for torque on the screws but maybe it's just feel. Quote
dkkim73 Posted November 1 Report Posted November 1 On 10/31/2024 at 1:23 AM, Schllc said: There were a few spider cracks around the screws they I glued but couldn’t hide. Did you use cyanoacrylate (super glue) or something more specific? Any vacuum technique or just capillary action? David Quote
Schllc Posted November 1 Report Posted November 1 58 minutes ago, dkkim73 said: Did you use cyanoacrylate (super glue) or something more specific? Any vacuum technique or just capillary action? David Removal is as simple as it looks. Just CA with capillary action, and the screws are just “feel” tite, then a 1/4 or less turn. Too tight and you can crack the glass. Be very careful with the CA because it can fog the acrylic. I think most of the stress on the plastic is from the screws, not air pressure, so gluing was more of a proactive step and isn’t required. Unless a chip breaks off or the crack is propagating. good news is if they can’t be cleaned to look better you have lost nothing. I have done this on several planes. The first set I ordered and trimmed and drilled. It took a lot of time to get it right, and I didn’t try to cut anything when trimming. I used a belt sander clamped to a bench. I didn’t have anyway to stabilize the plastic to cut, even with a bandsaw and was concerned it would break. most of the buffing can be done while on the plane, but The last few steps and to touch up around the screws you must take it off the plane. 1 Quote
