Yariv Posted May 5, 2024 Report Posted May 5, 2024 Hi, this is my latest issue - I cannot lower the flaps to take-off setting before take-off. When I lower the flaps lever, nothing happens. I have to lower it to full flaps and then raise it up to take-off position to make it work. Raising the flaps from take-off position works fine. it was explained to me that it involves upper limit switches and down limit switches and that in this case it is probably due to a down limit micro switch malfunction. Has anyone experienced this before? thanks, Yariv
PT20J Posted May 5, 2024 Report Posted May 5, 2024 Someone posted this schematic a while back. It sounds like a problem with the takeoff down limit switch. Flap switch logic.pdf 1
Yariv Posted May 5, 2024 Author Report Posted May 5, 2024 1 hour ago, PT20J said: Someone posted this schematic a while back. It sounds like a problem with the takeoff down limit switch. Flap switch logic.pdf 75.18 kB · 3 downloads Thank you very much for that. 1
Stephan Kablitz Posted May 9, 2024 Report Posted May 9, 2024 Dear Yariv, we had a similar problem on our M20J. You could not retract the flaps from full to take-off setting. Retracting completely did work however. We also were quite convinced that it would have to be a limit-switch problem. After changing the switch the problem was unchanged. We then had to learn that a cable was chewed up by a mouse that had lived behind the sidewall lining of the baggage compartment. Wouldn't hurt to have a kook, I think... 1
Yariv Posted May 14, 2024 Author Report Posted May 14, 2024 Thanks Stephan. I hope it’s not the case here as my airplane sits in a hangar with cowl plugs in place. I’ll update the thread in July after the airplane comes back from its annual inspection.
skykrawler Posted May 14, 2024 Report Posted May 14, 2024 Don't some of the newer models have 3 commanded flap position (rather than continuous)? There was a bulletin to convert to that design which had an additional switch installed in the back. Is this one of those models?
Yariv Posted May 20, 2024 Author Report Posted May 20, 2024 On 5/14/2024 at 3:32 AM, skykrawler said: Don't some of the newer models have 3 commanded flap position (rather than continuous)? There was a bulletin to convert to that design which had an additional switch installed in the back. Is this one of those models? It is the original design, 3 position flap lever - up, take-off, and full flaps.
