I know there are lots of posts here on door seal replacement, including one from @Gee Bee Aeroproducts that all have me confused.
My seal got pinched on the front side and is now perforated and prolapsing through the door/fuselage gap.
I’m not interested in a seal that mounts on the fuselage, which many of the after-market ones seem to do.
if someone could direct me to an off-the-shelf replacement and associated adhesive, I’d really appreciate it.  Meantime, perhaps some glue will fix the hole.
-dan
Dan, I'll hunt down the company who supplied me with one as it fit well. I used glue gone and mek to clean well,  and 3M "gorilla snot" to adhere the new seal. Expect closing difficulty until new seal is "broken in" to the frame.
A few days in the f47 Sun will expedite this
Not sure about the replacement or adhesive, but Peerco 321 Adhesive Remover did a great job removing the old glue from my door where the seal used to be without stripping any paint.
https://www.aircraftspruce.com/catalog/cspages/peerco02-00234.php
My research showed off-the-shelf factory-style replacements weren't easily available.  But I did stop short of calling the factory.  Hope you find one.
-dan
I went with the self stick fuselage mounted seal a few years ago but wasn’t crazy about the idea either; too easy to damage dragging bags out.
Definitely agree, a few years ago I needed the luggage door seal replaced and the shop used the fuselage type and I was pissed because I knew intrinsically by looking at it that it would get pitted and destroyed just by light use, and I was correct. By annual time the next year, it was nearly gone from the bottom of the frame and I had my shop install the correct type, which is glued to the hatch.
10 hours ago, Gee Bee Aeroproducts said:
The new silicone revised will Completed next week
Right version 1 , was copy of original in silicone
LH side revised -2
thinner wall , easier closure
The one on the left certainly looks like it would fill a bigger gap around our not-so-perfect-fitting doors and, as GB says, be easier to close.  The silicone should last a long time.  Nice innovation.
Your correct, there are tolerances in many doors
version 1 fit some
Customer called and asked if we could mfgvsa thinner wall  , two weeks later it was shipped .
version -2 will be used from know on
I will also work well on the baggage door .
GB
  • 10 months later...
