Fly Boomer Posted September 3, 2023 Report Posted September 3, 2023 1 hour ago, 1980Mooney said: Something doesn't make sense. If it is N888DF, ADSBExchange shows it flying in north TX, north LA and south AR as late as July 24, 2023. It is blocked on FlightAware. So it appears to be a fairly recent incident - maybe a prop strike. But the incident flight to north Arkansas doesn't show up. https://globe.adsbexchange.com/?icao=ac3bde&lat=33.160&lon=-93.600&zoom=9.6&showTrace=2023-07-24&trackLabels It is a Missile conversion with an IO-550A and a crazy expensive full feathering Hartzell Scimitar prop. Here is an ad from around 2015 - N888DF | 1992 MOONEY M20J 201 MISSILE on Aircraft.com That is a terrible place to be replacing an engine and prop. A Missile requires a lot more manhours/complexity to remove/replace/set up compared to a regular J. Working uncovered in the sun, rain and dirt can't be conducive to the best installation. They need a crane truck too. This same plane suffered a left gear collapse by a new owner in 2011 - slide off the runway and tore the plane up pretty good. "AIRCRAFT LANDING ON RUNWAY 2 AT LOT. ON ROLLOUT, THE LEFT MAIN LANDING GEAR COLLAPSED SLOWLY AND THE AIRCRAFT SKIDDED TO THE LEFT, HIT A RUNWAY LIGHT, CROSSED INFIELD GRASS BETWEEN RUNWAYS, CROSSED RUNWAY 9/27 AND STOPPED IN THE GRASS TO THE NORTH OF RUNWAY 9/27 AND WEST OF RUNWAY 2/20. DAMAGE TO PROP, LEFT WING LEADING EDGE, LEFT FLAP AND AILERON, LEFT HORIZONTAL STABILIZER LEADING EDGE AND TOP SKIN, AFT BOTTOM OF FUSELAGE, REAR BULKHEAD AND BULKHEAD UNDER HORIZONTAL STABILIZER. AIRCRAFT JACKED AND THE LANDING GEAR LOWERED. AIRCRAFT TOWED TO WINDWALKER AVIATION HANGAR." I think operating a Missile off a turf strip would be asking for trouble. Maybe it was a forced landing?
1980Mooney Posted September 3, 2023 Report Posted September 3, 2023 39 minutes ago, Fly Boomer said: I think operating a Missile off a turf strip would be asking for trouble. Maybe it was a forced landing? Good point.
Planegary Posted September 4, 2023 Report Posted September 4, 2023 Spoke with the holder of the photo. He said it was 3 monthes old and the plane left within the last 3 monthes since he was there this weekend and it had left 1
Fly Boomer Posted September 4, 2023 Report Posted September 4, 2023 46 minutes ago, Planegary said: Spoke with the holder of the photo. He said it was 3 monthes old and the plane left within the last 3 monthes since he was there this weekend and it had left Hope whatever downed it got fixed or gets fixed soon.
Lax291 Posted December 7, 2023 Report Posted December 7, 2023 Side to side Mooneys, one hasn't flown since 2009 (based on ADSB data) and the other flew a few months ago. Can you tell which one is which...? This is at Hartford Brainard KHFD.
hammdo Posted December 7, 2023 Report Posted December 7, 2023 Left - has a flat tire on the front… -Don 1 1
Hank Posted December 7, 2023 Report Posted December 7, 2023 54 minutes ago, Lax291 said: Side to side Mooneys, one hasn't flown since 2009 (based on ADSB data) and the other flew a few months ago. Can you tell which one is which...? This is at Hartford Brainard KHFD. ADSB data will give roughly the same information on my Mooney. Because I don't participate in ADSB, and have nothing installed to do so with if I wanted to. 1
ZuluZulu Posted December 7, 2023 Report Posted December 7, 2023 There used to be a Porsche Mooney parked at San Carlos (SQL) that always made me sad to see. Anyone know if it’s still there? It wasn’t far from the tower if I remember right.
Shadrach Posted December 7, 2023 Report Posted December 7, 2023 Freeway airport off Rt 50 on the MD Eastern shore. Image is from google streets. When I drove by this summer, the make shift cover for the baggage compartment was missing and completely open to the elements.…
Hector Posted December 8, 2023 Report Posted December 8, 2023 I posted a couple of years ago seeking advice on an overhaul for a bravo. There is a Bravo at my airport that had a top overhaul, flew for 5 hours, and has now been in a hangar for probably 20 years. Folks have approached the owner but he wants a lot of more than anyone is willing to offer considering the engine has not turned over in 20 years. I looked at it once because frankly the paint still looks good but the fuel tanks were bone dry and could see the sealant cracked. Considering the cost of the overhaul and tank reseal and all the other things that go bad from inactivity for so long I decided what I could offer is so far from what the owner is looking for that it was not worth even asking. It is still in the hangar today. Sent from my iPad using Tapatalk Pro 1
ZuluZulu Posted December 8, 2023 Report Posted December 8, 2023 16 minutes ago, Hector said: I posted a couple of years ago seeking advice on an overhaul for a bravo. There is a Bravo at my airport that had a top overhaul, flew for 5 hours, and has now been in a hangar for probably 20 years. Folks have approached the owner but he wants a lot of more than anyone is willing to offer considering the engine has not turned over in 20 years. I looked at it once because frankly the paint still looks good but the fuel tanks were bone dry and could see the sealant cracked. Considering the cost of the overhaul and tank reseal and all the other things that go bad from inactivity for so long I decided what I could offer is so far from what the owner is looking for that it was not worth even asking. It is still in the hangar today. Sent from my iPad using Tapatalk Pro Man, what a waste.
1980Mooney Posted December 8, 2023 Report Posted December 8, 2023 15 hours ago, Rmfriday said: The registration is still current per the FAA. Hope springs eternal. This also highlights that the list of about 7,000 Mooney's registered world wide is not the number flying....
Igor_U Posted December 9, 2023 Report Posted December 9, 2023 This picture was taken 5 years ago at Hodges airpark, south of Savannah. I was told it was sitting there for a long time but now it's not visible on Google Satellite photo and flightaware shows some intrepid sole flew it in 2022. I hope it gets restored...
hammdo Posted December 9, 2023 Report Posted December 9, 2023 Such a shame to see these sitting… -Don
1980Mooney Posted December 9, 2023 Report Posted December 9, 2023 2 hours ago, Kelpro999 said: returning to earth FAA shows that this one was deregistered in 2018....
toto Posted December 9, 2023 Report Posted December 9, 2023 13 hours ago, Igor_U said: This picture was taken 5 years ago at Hodges airpark, south of Savannah. I was told it was sitting there for a long time but now it's not visible on Google Satellite photo and flightaware shows some intrepid sole flew it in 2022. I hope it gets restored... Looks like this one starred in a movie at some point. (Link goes to a bunch of photos on a movie set.) 1
1980Mooney Posted December 9, 2023 Report Posted December 9, 2023 3 hours ago, Igor_U said: This picture was taken 5 years ago at Hodges airpark, south of Savannah. I was told it was sitting there for a long time but now it's not visible on Google Satellite photo and flightaware shows some intrepid sole flew it in 2022. I hope it gets restored... FAA shows that the registration was "cancelled" in 2013. I bet it got scrapped. Sometimes the wrong N number gets attributed to a flight on FlightAware - especially in pre ADS-B aircraft.
Schllc Posted December 9, 2023 Report Posted December 9, 2023 Something about boats and airplanes, where some aging folk, usually with comfortable money reserves, just pay to watch them rot until they die. It’s difficult to understand, but I attribute it to not wanting to let go of that period, memory or ambition. I suspect we all get there, hopefully we don’t take our birds down with us! 2
hubcap Posted December 9, 2023 Report Posted December 9, 2023 1 hour ago, Schllc said: Something about boats and airplanes, where some aging folk, usually with comfortable money reserves, just pay to watch them rot until they die. It’s difficult to understand, but I attribute it to not wanting to let go of that period, memory or ambition. I suspect we all get there, hopefully we don’t take our birds down with us! If I lose my medical, Myrtle goes up for sale the next day.
Pinecone Posted December 9, 2023 Report Posted December 9, 2023 In some cases, I think it is that the plan is next year. This year is too busy, but next year I will fly, sail, drive, etc
Kelpro999 Posted December 9, 2023 Report Posted December 9, 2023 10 hours ago, 1980Mooney said: FAA shows that this one was deregistered in 2018.... Earth is pulling hard
