I am trying to remove the interior of my 1970 M20E, and I got stuck removing the handle pictured below. I guess it is for the air vents for the passengers in the back seat. There is one on each side, and even though I removed the screw in the center, neither one seems to budge at all. I tried shaking it, pulling hard, no success. I don’t want to break them…
Any suggestions?
Thanks!
That's the seat recline lever for the two seat backs. With the screw removed, you should be able to wiggle it off eventually.
23 minutes ago, Utah20Gflyer said:
It pulls straight off,  I’ve removed those before so I am absolutely sure.  Yours must be on extra tight.
Probably hasn't been off for a couple of decades. My own was last off ~Oct 2007. Likely won't come off without some effort.
If it were me I would spray in some lubricant,  then put a layer of high quality duct tape on both sides of the lever,  then carefully use some channel locks to gently rock back and forth while also pulling straight off.
