Derrickearly Posted November 5, 2022 Report Posted November 5, 2022 (edited) Just finished leaning to peak at 7000 ft, and the engine started running rough. Similar to 3 of 4 cylinders firing. I reverted to full rich. Turned on the boost pump. Cycled left, right and back to both magnetos. No change. Just started to look for a place to make a precautionary landing, and the roughness cleared. I switched fuel tanks, and continued my flight without a recurrence. Any ideas? I was thinking maybe a bit of water in the fuel. I drained both sumps. The right had a few drops of water, and the left was clear. I was flying on the left when the engine was rough. I also drained the sump in the cockpit during preflight using 5 seconds on both sides. Scratching my head. Edited November 5, 2022 by Derrickearly Grammar
Lionudakis Posted November 5, 2022 Report Posted November 5, 2022 I had a similar occurance KOSH bound over the summer about an hour into flight. only lasted a few seconds. The roughness went away quicker than my elevated pulse. I decided it was a small amount of water, despite the usual sumping. 1
ArtVandelay Posted November 5, 2022 Report Posted November 5, 2022 Engine monitor data?This is an example of what losing a cylinder for a few moments looks like: 1
Danb Posted November 5, 2022 Report Posted November 5, 2022 Here’s another illustration of dead cylinder, clogged injector. It does get your attention especially at 500 ft. 1
PT20J Posted November 5, 2022 Report Posted November 5, 2022 That’s exactly what happened to me on a trip. Happened again a few hours later on the same trip. Pulled the injectors when I got home and found one partially clogged. All good after cleaning them. 2
ArtVandelay Posted November 5, 2022 Report Posted November 5, 2022 Mine was the flight home from an annual, it went away and didn’t return. 1
Derrickearly Posted November 5, 2022 Author Report Posted November 5, 2022 2 hours ago, ArtVandelay said: Engine monitor data? This is an example of what losing a cylinder for a few moments looks like: Thank you! I didn’t think to look at the egt and cht readings. Now I know what to look for.
Derrickearly Posted November 5, 2022 Author Report Posted November 5, 2022 2 hours ago, Danb said: Here’s another illustration of dead cylinder, clogged injector. It does get your attention especially at 500 ft. Thank you! I didn’t think to look at the egt and cht readings. Now I know what to look for.
Derrickearly Posted November 5, 2022 Author Report Posted November 5, 2022 Sounds like I should discuss this with my mechanic.
A64Pilot Posted November 6, 2022 Report Posted November 6, 2022 I think you need to replace fuel cap O-rings, any amount of water is not a normal condition, you should never find water. I’ve never seen water come from anywhere except a leaking fuel cap myself 1
Hank Posted November 6, 2022 Report Posted November 6, 2022 1 hour ago, A64Pilot said: I think you need to replace fuel cap O-rings, any amount of water is not a normal condition, you should never find water. I’ve never seen water come from anywhere except a leaking fuel cap myself Be sure to disassemble the cap and change the little o-ring around the center pin. You'll need a new, small cotter pin to put it back together. 1
PT20J Posted November 6, 2022 Report Posted November 6, 2022 The fuel lines do not feed from the bottom of the tanks. That’s why there is so much unusable fuel. It takes a lot of water in the tank to get to the engine and then it will likely just quit. 3
ArtVandelay Posted November 6, 2022 Report Posted November 6, 2022 5 hours ago, PT20J said: The fuel lines do not feed from the bottom of the tanks. That’s why there is so much unusable fuel. It takes a lot of water in the tank to get to the engine and then it will likely just quit. Shouldn’t be any water if you’ve sampled your tanks during preflight. 2
