Philip France 13 Posted September 10, 2022 Report Posted September 10, 2022 Hello Engine pressure reading too high on fresh installed G3X EIS. I estimate is reading 3 to 4 inch too high, anybody had similar issue, Quote
EricJ Posted September 10, 2022 Report Posted September 10, 2022 Which pressure are you worried about? They all seem okay. Edit: I'm guessing you mean manifold pressure. At 10kft that does seem high if you don't have a turbo. When on the ground you can compare it to your altimeter setting with appropriate conversions for field elevation to determine whether it is off or how much. 1 Quote
PT20J Posted September 10, 2022 Report Posted September 10, 2022 There is no calibration on the G3X for manifold pressure, so it is most likely a bad transducer. It’s also good to check that the tiny drain hole in the line is clear to keep liquid from making it’s way to the transducer. 1 Quote
Philip France 13 Posted September 12, 2022 Author Report Posted September 12, 2022 Thank you i will check it Quote
