Theo Posted September 16, 2009 Report Posted September 16, 2009 The CHTs have always been boarderline high on my M20C. Enough so to require step climbs for cooling after a fuel stop, but not really an issue on the first take off of the day. I have sealed the dog house up and had several mechanics look at it - plus it has done this on three different sets of cylinders! - so I am thinking about adding the cowl closure mod. Has anyone on the forum done this and noticed a difference in CHT reading? Quote
piperpainter Posted September 16, 2009 Report Posted September 16, 2009 I've never had a problem with my CHT. I have the cowl closer and it looks great. But I can't tell you what it did before cause I had it when I got the airplane. But I know it looks better than the big hole they had originally! Quote
GeorgePerry Posted September 16, 2009 Report Posted September 16, 2009 My 74 has the cowl closure mod and I have no problems with CHT's...OBTW I used a EDM-700 to measure CHT, so it's pretty accurate If your running hot the first thing I would look at is the baffling and the cowl flap rigging. If your baffling is tight and your cowl flaps open the correct amount then you might want to have your mixture checked to see if the engine is running "pre-leaned" i.e. there's not enough fuel getting to the cyclinders. Quote
N207LS Posted September 16, 2009 Report Posted September 16, 2009 With what device/gauge are you checking your CHTs. My UBG-16 with CHT probes on all 4 cylinders shows a descrepancy with the original CHT gauge. Prior to the UBG-16 I had the EI 8A analyzer and it had similar descrepancies (although only had 2 CHT probes). I think that the gauge may have as much to do with the higher CHTs as the actual cowling. With that said, I have the complete closure (ARI, see my photos in my gallery) and get high temperatures on the original gauge during initial climb out, but am showing at least 30-40 degrees cooler on the UBG-16 accross all of the cylinders. Aaron Quote
Theo Posted September 16, 2009 Author Report Posted September 16, 2009 Thanks for the suggestion. I will add the mixture check to the squawk list for annual this winter. We have gone over the baffling and cowl flaps with the local mechanic and at Joey Coles a couple of years ago when he did a new top, but that is worth another look too I suspect. I am useing a JPI EDM-800. It does read a bit higher than the factory guage on #3 where there are two probes. It is #4 that usually wants to get too hot though. If all I had was the factory guage I wouldn't even know about it. I have always thought it was interesting that in Bob Kromer's test flight article from 2000 he had near red line CHT for a some of his climb. This sort of led me to think it was the nature of the beast in some respects. I assume he was just using the stock guage on #3. Makes me wonder what the other three cylinders were doing. Bob's test data: Continuous Climb Data 1966 M20C N3411XFull throttle, 2700 rpm, mixture leaned to 100-125 degreesrich of peak, cowl flaps open, airspeed as noted ElapsedTime Altitude MIAS MP RPM OilTemp CHT OAT Rate ofclimb* Climb#1 Airspeed at Constant 100MIAS 0:00 1000' 100 27.8 2700 200 400 97 --- 1:02 2000' 100 26.9 2700 200 440 92 968 2:40 3000' 100 25.9 2700 205 440 89 612 3:57 4000' 100 24.9 2700 205 430 84 779 5:08 5000' 100 23.9 2700 205 415 81 845 6:30 6000' 100 23.0 2700 200 415 79 732 8:04 7000' 100 22.1 2700 200 420 73 638 9:47 8000' 100 21.2 2700 200 415 69 582 11:37 9000' 100 20.4 2700 200 415 64 545 13:42 10,000' 100 20.0 2700 200 415 59 521 ElapsedTime Altitude MIAS MP RPM OilTemp CHT OAT Rate ofclimb* Climb#2 Airspeed at Constant 120MIAS 0:00 1000' 120 27.8 2700 205 410 98 --- 1:00 1800' 120 27.0 2700 205 425 96 800 2:00 2550' 120 26.2 2700 205 430 92 750 3:00 3480' 120 25.2 2700 205 425 88 930 4:00 4080' 120 24.7 2700 205 425 82 600 5:00 4860' 120 24.1 2700 205 425 79 780 6:00 5570' 120 23.2 2700 205 420 74 710 7:00 6250' 120 22.9 2700 205 415 72 680 8:00 6680' 120 22.4 2700 205 410 70 630 10:00 8680' 120 21.7 2700 205 405 65 500 12:00 8950' 120 21.9 2700 205 405 60 270 14:00 9320' 120 20.1 2700 200 405 56 335 15:46 10,000' 120 19.7 2700 200 405 54 385 * Under perfect flight test conditions, rate of climb should decrease smoothly as altitude increases. However, the air was very turbulent on our day of the test, so that is the reason why the numbers don't decrease evenly. Nevertheless, this test was a good one for 'real world' conditions and is pretty representative of what a C model will do on a hot day. Quote
Lood Posted September 17, 2009 Report Posted September 17, 2009 I'm having the lower cowl closure mod done within the next month. Partly becuase of the cosmetic improvement but mainly because of the improved cooling and small speed advantage it is supposed to offer. I don't really a have high CHT problem, but rather a somewhat high oil temperature. My Mooney still uses the factory style single cylinder analogue CHT gauge but I am also upgrading to a JPI 700. I manage to avoid the CHT to ever go higher than 400 deg F by playing around with the mixture and cowlflaps. My oil temperature bothers me some days. Although it stays in the green, it stays too close to the 200 deg mark. I plan to do the oil cooler relocation mod next. Apparently this mod has a huge improvement in oil temperature and overall engine cooling. Quote
The-sky-captain Posted September 17, 2009 Report Posted September 17, 2009 I've got the JPI 700 with fuel flow, cht temps... I would like to add oil temp. Any idea on the cost to do this? Quote
VanH Posted September 17, 2009 Report Posted September 17, 2009 Just got the oil temp probe, it was around $300. V Quote
Flybeech21 Posted September 24, 2009 Report Posted September 24, 2009 WOW! $300. I just priced an oil temp probe for a little over $100. Maybe you have a different probe than me since I have a M20C. I would bet the probe is the same though.. Quote
