PT20J Posted February 25, 2023 Report Posted February 25, 2023 Since you have it that far apart, you might consider removing the ceiling and baggage compartment panels and replacing the fiberglass insulation with the Mylar-backed foam. I did that and I think it keeps the airplane cooler when outside in the sun and warmer when the heater is in use. I don't think it made a lot of difference in the noise level, but I didn't measure it.
ArtVandelay Posted February 25, 2023 Report Posted February 25, 2023 I will 3rd the removal of annunciator and would also move the compass to the panel to clean up view.
gevertex Posted February 25, 2023 Author Report Posted February 25, 2023 35 minutes ago, PT20J said: Since you have it that far apart, you might consider removing the ceiling and baggage compartment panels and replacing the fiberglass insulation with the Mylar-backed foam. I did that and I think it keeps the airplane cooler when outside in the sun and warmer when the heater is in use. I don't think it made a lot of difference in the noise level, but I didn't measure it. I need to redo the interior at some point. I’ll address the insulation then. I had no idea there was fiberglass elsewhere in the airplane. I’ll check it out
PT20J Posted February 25, 2023 Report Posted February 25, 2023 6 minutes ago, gevertex said: I need to redo the interior at some point. I’ll address the insulation then. I had no idea there was fiberglass elsewhere in the airplane. I’ll check it out Yeah, I was surprised, too. I have a ‘94 MSE. Apparently Mooney saved a few bucks by only putting the foam on the sides. 1
gevertex Posted February 25, 2023 Author Report Posted February 25, 2023 20 minutes ago, ArtVandelay said: I will 3rd the removal of annunciator and would also move the compass to the panel to clean up view. I’ll ask again about the annunciator. They might be too far along at this point. I am also at budget for this project. I am hesitant to spend more at this stage. It probably wouldn’t be too expensive though. I like the idea.
gevertex Posted February 25, 2023 Author Report Posted February 25, 2023 5 minutes ago, PT20J said: Yeah, I was surprised, too. I have a ‘94 MSE. Apparently Mooney saved a few bucks by only putting the foam on the sides. Nice. We have basically the same airplane. 1
PT20J Posted February 25, 2023 Report Posted February 25, 2023 11 minutes ago, gevertex said: I’ll ask again about the annunciator. They might be too far along at this point. I am also at budget for this project. I am hesitant to spend more at this stage. It probably wouldn’t be too expensive though. I like the idea. Well, we all have to stop somewhere. In my case, I still and Gear Down, Gear Unsafe, Speed Brake, Pitot Heat, Alt Volts, Start Power, and Boost Pump lights, so I just left the annunciator panel connected. I like having those annunciators grouped together and I had room in the radio stack. But, everyone has their priorities. For me $80K+ installed was enough, though. 1
Fly Boomer Posted February 25, 2023 Report Posted February 25, 2023 12 hours ago, PT20J said: Since you have it that far apart, you might consider removing the ceiling and baggage compartment panels and replacing the fiberglass insulation with the Mylar-backed foam. I did that and I think it keeps the airplane cooler when outside in the sun and warmer when the heater is in use. I don't think it made a lot of difference in the noise level, but I didn't measure it. What product, what thickness, and what adhesive?
PT20J Posted February 25, 2023 Report Posted February 25, 2023 1 hour ago, Fly Boomer said: What product, what thickness, and what adhesive? I purchased the Mooney material in bulk from Oasis Aero in Willmar MN. It comes with the Mylar on one side and peel and stick adhesive on the other. 1
Philip France 13 Posted February 25, 2023 Report Posted February 25, 2023 Hello here is my panel as benchmark
Fly Boomer Posted February 25, 2023 Report Posted February 25, 2023 3 hours ago, PT20J said: I purchased the Mooney material in bulk from Oasis Aero in Willmar MN. It comes with the Mylar on one side and peel and stick adhesive on the other. When you say "Mooney material" is that a factory item?
gevertex Posted February 25, 2023 Author Report Posted February 25, 2023 1 hour ago, Philip France 13 said: Hello here is my panel as benchmark Looks great. Fixed that for those of us that can't see upside down. 1
PT20J Posted February 25, 2023 Report Posted February 25, 2023 1 hour ago, Fly Boomer said: When you say "Mooney material" is that a factory item? Yes, it came from Mooney. 1
gevertex Posted March 3, 2023 Author Report Posted March 3, 2023 Final panel design. Being cut now. I was able to get the shop to replace many of the switches with circuit breaker switches. They did not want to replace the field alternator or master switches. Added 2x LEMO plugs on the panel and moved GA headset plugs to panel. N9127S Pilot Draft 7.pdf 1
Aerodon Posted March 4, 2023 Report Posted March 4, 2023 On 3/2/2023 at 7:09 PM, gevertex said: Final panel design. Being cut now. I was able to get the shop to replace many of the switches with circuit breaker switches. They did not want to replace the field alternator or master switches. Added 2x LEMO plugs on the panel and moved GA headset plugs to panel. N9127S Pilot Draft 7.pdf 89.15 kB · 5 downloads I found a typo, did you?
gevertex Posted March 4, 2023 Author Report Posted March 4, 2023 29 minutes ago, Aerodon said: I found a typo, did you? I hope you are joking. Where? I can still correct it.
Aerodon Posted March 4, 2023 Report Posted March 4, 2023 5 minutes ago, gevertex said: I hope you are joking. Where? I can still correct it. No, not joking.
Andy95W Posted March 4, 2023 Report Posted March 4, 2023 (edited) AVIOD EQUIPED Edited March 4, 2023 by Andy95W 1
Steve0715 Posted March 4, 2023 Report Posted March 4, 2023 Nice proof reading Aerodon and Andy. You had to open the file to zoom in enough to read the print. Now the OP can make it right.
gevertex Posted March 4, 2023 Author Report Posted March 4, 2023 9 hours ago, Andy95W said: AVIOD EQUIPED Thanks guys. I though someone was yanking my chain at first.
Aerodon Posted March 4, 2023 Report Posted March 4, 2023 I would move this SPEED BRAKE EQUIPED: FOR OPERATING INSTRUCTIONS AND LIMITATIONS SEE SUPPLEMENT IN OWNER'S MANUAL OR PILOTS OPERATING HANDBOOK. " to the left hand side along with the other 'placard' Also, can it be shortened by deleting 'or pilots operating handbook'? What does the STC say? Don
Steve0715 Posted March 4, 2023 Report Posted March 4, 2023 1 hour ago, Aerodon said: SPEED BRAKE EQUIPED Did you mean to misspell EQUIPPED?
Aerodon Posted March 5, 2023 Report Posted March 5, 2023 8 hours ago, Steve0715 said: Did you mean to misspell EQUIPPED? That was a cut and paste from the panel file. I found Aviod, Andy found Equiped. I didn't post my find immediately because I knew that if you looked more you would probably find more. Aerodon
mooneyflyfast Posted March 5, 2023 Report Posted March 5, 2023 On 2/17/2023 at 10:25 AM, gevertex said: Closing in on getting this finished. Question for the group. I am looking at putting new switches in since the rockers are hard to come by / expensive. Do they need to be TSO or will anything work? Any recommendations / links? For instance, I have seen others with toggle switches in place of the rockers. Thanks! Some of those rocker switches have a built in breaker. My avionics master went bad so my radio guy replaced it with a toggle switch and a three amp fuse as a temporary measure. I have obtained a correct replacement rocker switch (very difficult) but have been in no hurry to get it installed.
gevertex Posted March 5, 2023 Author Report Posted March 5, 2023 1 hour ago, mooneyflyfast said: Some of those rocker switches have a built in breaker. My avionics master went bad so my radio guy replaced it with a toggle switch and a three amp fuse as a temporary measure. I have obtained a correct replacement rocker switch (very difficult) but have been in no hurry to get it installed. The replacement switches are apparently breaker toggles and have a circuit breaker built in. I didn’t know that was a thing until recently. Kind of cool.
