I have some oil blowing back through the filler tube. I have to tighten it with pliers after checking pre-flight to seal it the best I can. The gasket (which is more of an o-ring if you ask me) is pretty old.  I can't seem to find one anywhere.  Does anyone know where I can get the "oil gage gasket" as Lycoming would call it?  1987 M20J.
I have a plane with a o320 that had the same problem.  Oil would make a mess on the firewall.  New o-ring wouldn't seem to help.  I replaced o-ring with a crush washer with some high temp RVT.  Good so far.
The gasket under the tube is a 72059.  The o-ring on the top of the disptick is 74068 for all IO-360 except the A1D6D.   source: Lycoming direct drive IO-360 parts catalog
