AerostarDriver Posted June 20, 2022 Report Posted June 20, 2022 On 3/15/2022 at 8:00 PM, MMsuper21 said: No AP or other radios. Keeping kx155 with KI209. Keeping VAC for PC. (Step is electric Removing Stratus ESG. Panel will be separate contacted Hendrics mfg. Now the dilemma is dual GI275 for 2 AMU extra. Or see if I can flush mount the G5s. The GI-275 removes the need for a GAD 13 and GAD 29B which can simplify some of the install. I have dual G5s and dual GI-275s, one MFD and one EIS. If I could have times things differently, I would have gone all GI-275s. 1
MMsuper21 Posted June 20, 2022 Author Report Posted June 20, 2022 Yes installer is pushing GI275. It's more capable, duals can replace all vac instruments, interface with VOR (kx155) display traffic map etc. and no GADs. He was initially recommending the G5s but now is all GI275 after digging into the documentation.
MMsuper21 Posted July 5, 2022 Author Report Posted July 5, 2022 Another update, the RC22 Allen vacuum units can only be adjusted up to 8°. The RC24 electric can be adjusted up to 16°. My flat panel needs an adjustment of 15°, verified both on the ground and in flight. Now debating to do an overhaul on a RC24 unit, second GI275, or add tilt to the panel.
MMsuper21 Posted October 4, 2022 Author Report Posted October 4, 2022 Finally some updates. Decided to keep her. Panel is almost done I will get some more pictures once I pick her up tomorrow. 1
MMsuper21 Posted October 6, 2022 Author Report Posted October 6, 2022 23 minutes ago, Pinecone said: What is that control lock setup? Home Depot Special for the bungee and amazon remove before flight tag.
