GT,
edit your title…
Use the words…. Bladders for M20J…
Or use the search…
Expect that there is a long running discussion about who uses what and why…
Where to buy..
Who does the installs…
How many bladders, for how much total useful fuel….
What you will find…
Proper resealing does a great job…
Modern materials, modern technique… much has changed over the last decade…
Bladders are good too… they have a different set of problems… including weight…
Its your plane… you decide…
All Mooney's come from the factory with "wet wing" fuel tanks.  Bladders are only seen as a retrofit solution.  This article is from 2009.  Double the prices mentioned in the article for a more accurate estimate of today's costs.
https://www.knr-inc.com/25-shoptalk/24-200910-ribs-wet-or-dry
I just had the left wing in a J model patched. It has Monroy extended range tanks added but they only found leaks in the main (original) tank - 4 leaks in total.  The cost of repair was $3,000.
Edited by 1980Mooney
The one I have has 93 Gal (just bought it) so I assume it has added tanks (Monroy Auxiliary Fuel Tanks (adds 29 US Gallons), Total is 93 US Gallons Useable) and those would be "bladders" but the others would be wet wings?
The Monroy Auxiliary tanks are just a wet wing extension of the basic original wet wing.
Well, I suppose thats good wrt overall weight :) Hopefully I have no leaks!!
Thanks for the info.
Is that layout of monroy tanks the same for an M20K 252 wing as a M20J?
Good question.  Isn't the K standard fuel capacity 75 gal vs. 64 in the J?  Something internal is slightly different.  I believe the external dimensions of both wings are the same as well as the internal structural components.
M20J.thumb.png.2ac0d74c3d52f755f9d36b4d8389ea57.pngM20K.thumb.png.1f333f85c247f39e427ea8ba4621fcf1.png
