Shmoo Posted November 22, 2021 Report Posted November 22, 2021 First post after buying my J in August is sadly a diagnosis/parts buy... The outboard corner of my right side cowl flap is disconnected from the hinge assembly. It looks like one of the angle brackets (p/n 650177 here best seen on page 7) is broken at the bend. Can I just replace that bracket? Or do I need to order and replace more of the hinge assembly? I hadn't noticed any vibrations and the other hinge attachment points feel firm. Here's a really bad photo. I outlined the disconnected piece of metal that i think is p/n650177. Thanks for the help! Otherwise she's been great!
KSMooniac Posted November 22, 2021 Report Posted November 22, 2021 You can replace or repair that bracket with standard practice. You might have to duplicate the bracket. Sent from my LM-V405 using Tapatalk
EricJ Posted November 22, 2021 Report Posted November 22, 2021 Duplicating the bracket is probably the easiest way to go. There's an SB on early J cowl flaps that has a lot of drawings and guidance on making an improvement if it hasn't already been done. There've been a lot of field modifications to these as well, from what I've seen. Mooney Service Bulletin M20-231. https://www.mooney.com/wp-content/uploads/2020/12/SBM20-231.pdf 1
N201MKTurbo Posted November 22, 2021 Report Posted November 22, 2021 It is not a good design. Mooney even admitted it in the service bulletin. As stated above just use standard sheet metal procedures to patch it back together for another 10 years or so. 1
jaylw314 Posted November 22, 2021 Report Posted November 22, 2021 I recall someone mentioning that for prevention, leaving the flaps in trail rather than fully open puts less stress on that hinge. If you live in a cooler climate, in the future see if you have manageable temps that way
mooneyflyfast Posted November 23, 2021 Report Posted November 23, 2021 Looks like there are two service kits- 001 and optional 002. Does anyone know what the difference is?
PT20J Posted November 23, 2021 Report Posted November 23, 2021 1 hour ago, mooneyflyfast said: Looks like there are two service kits- 001 and optional 002. Does anyone know what the difference is? Instructions say to install optional kit if not already installed, so it was probably available earlier.
