mhrivnak Posted August 9, 2021 Report Posted August 9, 2021 This is from my 1990 MSE (28V electrical system), which had less than 2200 total hours at the time these parts were removed and seems to have been hangared most or all of its life. There are more parts to post, but this is a start. Everything worked great when removed. Connectors and trays are included where applicable. I'll ship however you want from Raleigh NC; you just cover the actual shipping expense. KI 525A HSI $600 PN 066-3046-00 SN 39245 KMT 112 Azimuth Transmitter $100 PN 071-1052-00 SN 36415 KA 51B Slaving Control $150 PN 071-1242-06 SN 14034 KG 102A DG $400 PN 060-0015 SN 31372 United 7000 Vertical Speed Indicator $100 PN 7000 SN 90167 United Altimeter $300 PN 5934PA-1 SN 1F529 KMA 24 audio panel $150 PN 066-1055-03 SN 30320 InterVOX AA80 Intercom $100 PN AA80-001 SN 4459 Aero Safe Guardian I backup vacuum system $900 B&D Hour Counter / Hobbs Meter $100 PN 880035-507 B&D EGT/OAT Gauge $200 PN 880001-507 B&D Tachometer Gauge $160 PN 880039-515 United Manifold Pressure Gauge $200 PN 880044 Suction Gauge, UMA $50 PN 3-310-55 SN A3914 MidContinent Clock MD-88L $75 PN 206918 SN 4778 Quote
ZuluZulu Posted August 9, 2021 Report Posted August 9, 2021 @mhrivnak is your panel retaining the turn coordinator? Mine has somehow become fixed in place, as in, the little airplane does not move when I turn. Quote
mhrivnak Posted August 10, 2021 Author Report Posted August 10, 2021 On 8/9/2021 at 11:45 PM, ZuluZulu said: @mhrivnak is your panel retaining the turn coordinator? Mine has somehow become fixed in place, as in, the little airplane does not move when I turn. Expand Almost everything came out in favor of a G3x Touch, but I already sold the turn coordinator. Quote
carusoam Posted August 10, 2021 Report Posted August 10, 2021 Let’s get something better than a TC this time… They we’re good back in the day… but an AI will be better…. With an inclinometer tube… Best regards, -a- Quote
ZuluZulu Posted August 10, 2021 Report Posted August 10, 2021 On 8/10/2021 at 3:57 AM, carusoam said: Let’s get something better than a TC this time… They we’re good back in the day… but an AI will be better…. With an inclinometer tube… Best regards, -a- Expand I already have two G5s, this is for a backup. 1 Quote
carusoam Posted August 10, 2021 Report Posted August 10, 2021 On 8/10/2021 at 4:20 AM, ZuluZulu said: I already have two G5s, this is for a backup. Expand I’m on a mission to eliminate TCs… they wear and become less usable… without telling anyone… When you go to use it in ordinary bumpy weather… is when you find out how unusable it really is… So… consider getting a third AI instead…. We lost a local Brand B because he had an AI failure… and descended into the clouds using the TC…. Came out the bottom in pieces… How is that for a sales pitch? Best regards, -a- Quote
ZuluZulu Posted August 10, 2021 Report Posted August 10, 2021 On 8/10/2021 at 4:31 AM, carusoam said: I’m on a mission to eliminate TCs… they wear and become less usable… without telling anyone… When you go to use it in ordinary bumpy weather… is when you find out how unusable it really is… So… consider getting a third AI instead…. We lost a local Brand B because he had an AI failure… and descended into the clouds using the TC…. Came out the bottom in pieces… How is that for a sales pitch? Best regards, -a- Expand Don't need to work too hard to convince me of an upgrade; the plane will eventually get a full G3X Touch panel (or whatever Garmin comes out with by then to replace that). I'm only looking for a relatively cheap plug-and-play TC secondhand as a stopgap, but if anyone wants to sell me a cheap Lifesaver instead I won't complain. 1 Quote
