carusoam Posted November 3, 2021 Report Posted November 3, 2021 Great pireps on long term use of the YD…. Yaw Damper. Thanks for sharing them… and the logic that goes with the funny word…. Best regards, -a-
Hank Posted November 3, 2021 Report Posted November 3, 2021 1 hour ago, LANCECASPER said: We're not trying to dampen (to make damp or moist) the yaw, just trying damp (to check or retard the action) it. Yaw Damper. And here I thought you wanted the yaw to be reduced or made less strong . . . .
LANCECASPER Posted November 3, 2021 Report Posted November 3, 2021 16 minutes ago, Hank said: And here I thought you wanted the yaw to be reduced or made less strong . . . . Or we could just go with what the manufacturers call it
Hank Posted November 3, 2021 Report Posted November 3, 2021 1 minute ago, LANCECASPER said: Or we could just go with what the manufacturer calls it "Digital Autopilot" works for me! Why so much angst when I changed the OPS "dampner" to "dampener", but no throwback on the OP for putting that extra "n" into "damper"? To me, the damper is that adjustable plate in my chimney used to modulate airflow through the fire, and "dampner" is not a word at all.
LANCECASPER Posted November 3, 2021 Report Posted November 3, 2021 3 minutes ago, Hank said: "Digital Autopilot" works for me! Why so much angst when I changed the OPS "dampner" to "dampener", but no throwback on the OP for putting that extra "n" into "damper"? To me, the damper is that adjustable plate in my chimney used to modulate airflow through the fire, and "dampner" is not a word at all. He was corrected in post #2 by someone else and humbly admitted his error.
V1VRV2 Posted November 4, 2021 Report Posted November 4, 2021 I have an Ovation with a GFC500 yaw damper. I love it. Do not regret purchase. I do a GUMPSY check. Gear, undercarriage, mixture, prop, spoilers, yaw damper. Forgot to retract the spoilers more times than I’d like to admit.
dzeleski Posted November 4, 2021 Report Posted November 4, 2021 On 11/2/2021 at 1:08 PM, steingar said: Are there servos strong enough to move the trim wheel in the Mooney? I'd not have thought so, but I am no expert. Yes they are... but... There is a test that must be done after install, which is running the trim stop to stop in both directions in under a certain amount of time. My plane took too much time and needed some cleaning and lubing to the trim system for it to pass. My J did not have electric trim from the factory, it now has it via the GFC 500.
