brndiar Posted June 13, 2020 Report Posted June 13, 2020 Hi, Unfortunately during engine overhaul (Lycoming O360 A1D) the old (I think) Prestolite starter motor was not overhauled. Last time worked at "second attempt" and now is not working any more. Please advice regarding replacement. Thanks, M.
ShuRugal Posted June 13, 2020 Report Posted June 13, 2020 Hi, Unfortunately during engine overhaul (Lycoming O360 A1D) the old (I think) Prestolite starter motor was not overhauled. Last time worked at "second attempt" and now is not working any more. Please advice regarding replacement. Thanks, M. I'll happily recommend the the SkyTech starter. 10lbs lighter, and spins twice as fast for easier starts. 2
neilpilot Posted June 13, 2020 Report Posted June 13, 2020 Just be sure you know if your ring gear has 122 or 149 teeth. I know from experience that, at least in the case of my 64E, the IO360-A1A could have either ring gear. Either reference your old starter or just go out and count.
carusoam Posted June 14, 2020 Report Posted June 14, 2020 Verify the details.... But the skytech 149NL seems to be a good choice... requiring no cowl mods required to make it fit... 12 or 24V is also an important detail... https://mooneyspace.com/search/?q=Skytech 149NL&quick=1 Often the starter solenoid gets old and dirty causing the challenge.... be sure to clean all connections to keep from changing out some old parts that are still operational... Best regards, -a- 1
MooneyMitch Posted June 14, 2020 Report Posted June 14, 2020 As suggested, verify reason for non-performance of starter...... perhaps starter/bendix is good. However, +1 for Hartzel (Skytec)149NL. 1
mike20papa Posted June 14, 2020 Report Posted June 14, 2020 Skytech 149NL has served me with out fail for over ten years. You will need to close the area in the front baffle around the smaller drive housing - or else wonder why you now have increased oil temps with a new starter. 1 1
deanders Posted June 14, 2020 Report Posted June 14, 2020 I have a Prestolite starter I just removed from my E model. I removed it to install a Skytec. It has less than 100 hours since overhaul. If you want it I'll let it go for 100 bucks. The Skytec is a good option. 1
Jim Peace Posted June 15, 2020 Report Posted June 15, 2020 Skytec with a new concord battery.....you will be able to taxi with the starter going....
