HRM Posted May 14, 2020 Report Posted May 14, 2020 Two Brittain servos, appear to be working fine (pass the pulmonarius vacuum/pressure test--connectors will be wiped with disinfectant prior to shipping). $400+shipping (from 03NC) Quote
carusoam Posted May 20, 2020 Report Posted May 20, 2020 Message for a Harley... @HRM ^^^^ Come in... Harley...? -a- Quote
HRM Posted May 20, 2020 Author Report Posted May 20, 2020 41 minutes ago, carusoam said: Message for a Harley... @HRM ^^^^ Come in... Harley...? -a- What's your message? You know, I am not on here 24/7. 1 Quote
HRM Posted May 20, 2020 Author Report Posted May 20, 2020 46 minutes ago, RDuplechin said: Do you still have this available? Yep. Quote
carusoam Posted May 20, 2020 Report Posted May 20, 2020 Glad you found it... I probably went so quickly.... throwing arrows in the general direction of the post above (^^^^) ... you may not of recognized them.. By bad... Best regards, -a- Quote
HRM Posted May 20, 2020 Author Report Posted May 20, 2020 8 hours ago, carusoam said: Glad you found it... I probably went so quickly.... throwing arrows in the general direction of the post above (^^^^) ... you may not of recognized them.. By bad... Best regards, -a- That's OK, I get email notifications on any threads I create. A very nice feature of MS. Quote
Nukemzzz Posted June 29, 2020 Report Posted June 29, 2020 Are these the elevator or aileron servos? Quote
211º Posted July 4, 2020 Report Posted July 4, 2020 The cans and rubber are the same. The one with a cable was used in the tail cone for the rudder. The ones with chains are from the wing for the aileron. Sent from my iPad using Tapatalk Pro 1 Quote
cferr59 Posted July 4, 2020 Report Posted July 4, 2020 11 minutes ago, 211º said: The cans and rubber are the same. The one with a cable was used in the tail cone for the rudder. The ones with chains are from the wing for the aileron. Sent from my iPad using Tapatalk Pro True, but the servo itself only has a stud and you can swap the chain with the cable. Quote
211º Posted July 4, 2020 Report Posted July 4, 2020 11 hours ago, cferr59 said: True, but the servo itself only has a stud and you can swap the chain with the cable. Agreed. Quote
