skydvrboy Posted April 17, 2019 Report Posted April 17, 2019 I was changing looking in the wingtip this evening through the nav light hole and found this. Sorry about the poor picture quality, I tried to clean it up, but this was the best I could do. There appears to be a pile of something in the inside corner near the back of this chamber. I opened a few other inspection panels and didn't see anything like it anywhere else. Quote
EricJ Posted April 17, 2019 Report Posted April 17, 2019 Definitely get it out and inspect for corrosion in the area. Even if there wasn't animal urine it could have held moisture in there. Quote
skydvrboy Posted April 17, 2019 Author Report Posted April 17, 2019 It definitely won’t be easy to get to. There isn’t an inspection panel in that section. I’ll rig up a small hose duct taped to a vacuum cleaner and suck it out through the nav light hole. Quote
1964-M20E Posted April 17, 2019 Report Posted April 17, 2019 Yes get it cleaned out. While some may think it a waste of time at every annual all wing inspection covers are removed (4 to 6 hours to R&R) and I clean inside each bay to the best of my ability before applying corrosion X. The first few years are really dirty but it gets less and less over time. Sometimes I feel like a proctologists on an elephant reaching deep inside the wings as far as I can. 1 Quote
ArtVandelay Posted April 17, 2019 Report Posted April 17, 2019 My guess would be an old mouse nest. You need to do whatever has to be done to clean it all out of there and inspect the area for corrosion. Jim At the wing tip?, mice usually make their way into the tail via tie down rope? I would guess hummingbirds or flying insects. Not that it matters much, in either case it needs to be cleaned. Maybe got entry via gaps by ailerons? Did you check other wing?Tom Quote
Vance Harral Posted April 17, 2019 Report Posted April 17, 2019 4 minutes ago, ArtVandelay said: At the wing tip? Yep. They climb up the mains into the wheel wells, enter the wing where the retract rods pass through the wing to the wells, and thence through the holes in the wing ribs to wherever they like. Ask me how I know. Some Mooneys have "rat socks" where the retract rods enter the wheel wells, presumably in part to prevent this. Our airplane doesn't. It's unclear to me whether it left the factory that way, or if some prior owner removed them. 1 Quote
Shadrach Posted April 17, 2019 Report Posted April 17, 2019 7 hours ago, 1964-M20E said: Yes get it cleaned out. While some may think it a waste of time at every annual all wing inspection covers are removed (4 to 6 hours to R&R) and I clean inside each bay to the best of my ability before applying corrosion X. The first few years are really dirty but it gets less and less over time. Sometimes I feel like a proctologists on an elephant reaching deep inside the wings as far as I can. I do not believe that the MM specifies all inspection covers to be removed nor is necessary to inspect the wing in its entirety. One must be willing and able to use a mirror and a flashlight. One thing that gets neglected more are the wing root fairings. Whatever is in skydvrboy’s wing needs to come out now. Looks like it could be an old rag. Quote
Hank Posted April 17, 2019 Report Posted April 17, 2019 1 hour ago, Shadrach said: Whatever is in skydvrboy’s wing needs to come out now. Looks like it could be an old rag. That's better than the empty Coke bottle that was in a door of my grandparents' new Buick . . . 1 Quote
RLCarter Posted April 17, 2019 Report Posted April 17, 2019 32 minutes ago, Hank said: That's better than the empty Coke bottle that was in a door of my grandparents' new Buick . . . Guy here found a bucking bar in the wing of a new 182 during its 1st annual several years back 1 Quote
Guest Posted April 17, 2019 Report Posted April 17, 2019 2 hours ago, Shadrach said: I do not believe that the MM specifies all inspection covers to be removed nor is necessary to inspect the wing in its entirety. One must be willing and able to use a mirror and a flashlight. One thing that gets neglected more are the wing root fairings. Whatever is in skydvrboy’s wing needs to come out now. Looks like it could be an old rag. While it’s technically not required to open every panel on the wing, cases like this sure explain the need to do it once in a while. Clarence Quote
skydvrboy Posted April 17, 2019 Author Report Posted April 17, 2019 5 minutes ago, M20Doc said: While it’s technically not required to open every panel on the wing, cases like this sure explain the need to do it once in a while. Agreed, but don't forget, this area can not be viewed through any inspection panel. It is on the very tip of the wing and is only visible/accessible through the nav light hole. I took off the four outermost inspection panels and there was nothing like this in any of those compartments. Kind of makes me wonder how long it's been there. When I get it out, I'll report back on what it is (assuming I can figure that out once it's removed). I'll also spray some corrosion-X in there and try to get it covered well. 33 minutes ago, RLCarter said: Guy here found a bucking bar in the wing of a new 182 during its 1st annual several years back My other wing had a bucking bar in it from the previous wing repair. I let the mechanic keep it for his tool set. 2 Quote
Shadrach Posted April 17, 2019 Report Posted April 17, 2019 1 hour ago, M20Doc said: While it’s technically not required to open every panel on the wing, cases like this sure explain the need to do it once in a while. Clarence Agreed. I hope this turns out to be benign. Quote
skydvrboy Posted April 22, 2019 Author Report Posted April 22, 2019 Quick followup on what I found. It looks like the some insulation and fibers. It could have been a mouse nest, but there were no mouse droppings. I opened up all the inspection plates around this area and found nothing in any of the other compartments. The only way to access this area is through the nav light holes, so I made a make-shift vacuum cleaner hose by duct taping a section of garden hose onto the vacuum hose. I was able to get it all out except for a small amount on the back side of a 3/4" rib. I went to several stores around town, but couldn't find Corrosion-X, so once it was cleaned the best I could, I sprayed it with this stuff. If anyone takes off their nav light for any reason, inspect this area. It would NEVER be found through an annual inspection, PPI, etc. 3 Quote
carusoam Posted April 22, 2019 Report Posted April 22, 2019 Great follow-up, SDB! Best regards, -a- Quote
