And they hosed everyone on installs.... the new install manual basically requires a cheap plastic GPS antenna to be mounted on the glareshield.  And the new wire required is about $5 a foot, and is on backorder for 3-4 months
Expand
I think the antenna is only if the G5 is not connected to a WAAS navigation unit.  That is, if you want to use the internal G5 GPS receiver you have to install the glareshield antenna rather than an external antenna.
  On 4/10/2019 at 1:02 PM, gsengle said:
So does that mean a G3X install with a G5 backup would also be allowed for fiki?
Expand
Yep, there was no limitations put on the g3x as far as FIKI. It was already legal if you use legacy backup gauges.
Edit: webinar Q&A3A6A6660-CFB7-4BE3-AC45-A667F853219B.thumb.jpeg.7ce338f0353c8541033e99957d99d67a.jpeg
Edited by MIm20c
