My autopilot would not hold Alt hold. As soon as I engaged the AP and Alt Hold, the plane will trim start to nose down trim. Also, when using the heading bug in and making turns with new heading assignments, the AP will disconnect.
JT
10 hours ago, tigers2007 said:
Have you read Crocker’s blog on Century Autopilots?
https://www.google.com/amp/s/miscsolutions.wordpress.com/2011/02/16/troubleshooting-old-century-autopilots/amp/
Make sure the goofy connector contacts are clean. Consider Caig DeOxit D5 cleaner. https://caig.com/deoxit-d-series/
Thank you. Will read the info.
