New Price for these units is over $3000. This setup is perfect for a hangar or hangar home.
The core of the GK 415 is the Becker FAA-certified AR 4201 airborne transceiver, featuring 760 channels, 118-137 MHz frequency range, 25 kHz channel spacing, sunlight-readable backlit LCD, SETUP menu, BITE functions and DC voltage indication.
Included:
• GK 415
• Lead acid 2.2Ah battery
• Battery charger
• AC connector cable
• Whip antenna
• Carry case
• Dynamic Mic
Specifications
  • Supply Voltage: External 10.0 – 32.0 VDC via charging device for 115/230 V, AC internal 12 V, 2.2 Ah Dry-lead-acid battery
  • Power Consumption: Receive Current: 70 mA Transmit Current: 2.5 A
  • Frequency Range: 118.000 – 136.975 MHz
  • Frequency Channels: 760
  • Channel Spacing: 25 kHz
  • Memories: 99 Storage
  • Height: 3.15"
  • Width: 6.29"
  • Depth: 10.63"
  • Weight: 6.61lbs
  • Warranty: 2 years
  • Com is TSO/JTSO C74c, C88a
