carusoam Posted November 17, 2018 Report Posted November 17, 2018 Fred, See if you can find two manuals... parts Service and Maintenance The procedures are in the MM. The parts is an interesting catalog for every nut and bolt in the plane... Best regards, -a-
Mooneymite Posted November 17, 2018 Report Posted November 17, 2018 26 minutes ago, Fred_2O said: I'm assisting with the annual inspection the week after next. I watched last year as the annual was part of pre-buy inspection. This year I plan to be more engaged. Does anyone have instructions for checking the landing gear pre-load? I'd like to study that procedure before hand so I understand how it is done and what it accomplishes. Fred, as mentioned the MM has the necessary verbiage, however checking the gear pre-load is very much a hands on activity. Feeling exactly when the first movement of the link happens while moving the torque wrench takes a little practice. The nose gear preload is measured differently depending on model and year. 1
0TreeLemur Posted November 18, 2018 Report Posted November 18, 2018 19 hours ago, carusoam said: Fred, See if you can find two manuals... parts Service and Maintenance The procedures are in the MM. The parts is an interesting catalog for every nut and bolt in the plane... Best regards, -a- Thanks -a-. I've got both. Just thought maybe there was a separate doc with a concise description. 1
Yetti Posted November 19, 2018 Report Posted November 19, 2018 On 11/18/2018 at 3:37 AM, Fred_2O said: Thanks -a-. I've got both. Just thought maybe there was a separate doc with a concise description. There are some pretty good descriptions on here. do a google search mooneyspace gear preload Some involve using a cut up beer can as a feeler gauge. 1
Yetti Posted November 20, 2018 Report Posted November 20, 2018 I was never sure if you drank the beer before or after preload check 1
