bnicolette Posted May 1, 2011 Report Posted May 1, 2011 Hi all, Well we had a great trip to Niagara Falls on Saturday. Our first family adventure in the Mooney, weather was perfect and everybody had a blast. Question #1: I have been flying the Mooney (J model) since February. I have noticed a lot of talk about the red box when reading about the engine monitors and the leaning process. Most of my flying is point to point and usually a minimum of 170nm. I almost always file IFR (habit I suppose and lonely without it) and minimum altitudes of 7000’ usually. It appears to me that the red box doesn’t really come into play when at this altitude and really just wondering why one might fly lower than that when on a point to point trip? I am just wondering if I might be missing something? Is there an advantage to flying lower? I must admit that I haven’t spent much time in the POH when it comes to performance charts, but I would think that the optimum altitudes would be somewhere around 7 to 8 thousand feet? Question #2: I have posed this before but just about the CHT values. My #2 CHT is generally 50 degrees colder than the hottest CHT and the #2 EGT is about 60 degrees hotter than the coldest EGT? What do you guys think this could be due to? The spark plugs are brand new and the mag checks are normal so it’s not a plug issue? I had a compression check done before this trip and they were 75, 75, 79, 75. The engine has right around 600 hours SMOH. I have about 30 hours on the airplane now since I have owned it and the values have not changed, so possibly it’s just the way this engine is? I put the engine monitor in so the previous owner would not be of help? Any input? Thanks guys and blue skies to all. Brett Quote
scottfromiowa Posted May 1, 2011 Report Posted May 1, 2011 Hey Brett. Glad trip to Niagra Falls was good. I think there is an impressive collection of WWII aircraft just north in Canada. (Spitfire, Hurricane, ME-109, P-51, P-47 etc.) Might want to check that out some time. My #2 CHT is about 50 degrees hotter (consistently). I attribute this to probe position. I had an OEM probe so multi-probe was positioned differently. The key is consistency, as you know. If that is norm...all is good...if you notice a change time to inspect, right? EGT really doesn't matter accept for leaning/mag check. It's all about the cylinders temp. #'s on EGT will vary and aren't an issue. IF an EGT is wildly different (from group) may be a sign of a clogged injector, but a 50 degree difference not an issue (so I have read as they are just values). I am a VFR pilot and I fly at 6500-7,500 (or higher depending on winds), but if I have a cloud ceiling lower...I can't get on top...or if possible for ceiling below at destination...I might also have to stay lower...This happens more than you would think in the summer in Mid West for a VFR pilot. I agree that you shouldn't be at 70-75% of HP at those altitudes (in a J) and shouldn't be in the "red box". I don't run above 25 inches of manifold pressure down low and lean to 10-10.5GPH. Up high I lean to 30-50 LOP and firewall throttle with ram air open in my M20E. There are some really good engine management articles that can be found on other links that discuss the "red box" in detail. Some other links discuss in detail on Mooney Space. Quote
danb35 Posted May 1, 2011 Report Posted May 1, 2011 Differences in EGTs from cylinder to cylinder are meaningless. Significant differences in CHTs could mean something, but it could be anything from slight changes in baffling to a different type of CHT probe to... Quote
Parker_Woodruff Posted May 1, 2011 Report Posted May 1, 2011 my best TAS in my M20J was always between 6,000 and 9,000 depending on the day. I would be interested to know where your #2 cylinder is in relation to its peak EGT. Quote
bnicolette Posted May 1, 2011 Author Report Posted May 1, 2011 Parker, Here is the LF Report from EZ trends for one of yesterdays legs. TIME FF E1 C1 E2 C2 E3 C3 E4 C4 4/30/2011 11:36 10.7 1408 351 1472 321 1434 348 1415 353 4/30/2011 11:36 10.7 1410 352 1474 322 1435 350 1413 354 4/30/2011 11:36 10.7 1415 352 1473 319 1436 350 1416 353 4/30/2011 11:36 10.7 1417 352 1479 320 1440 350 1425 352 4/30/2011 11:36 10.7 1422 352 1482 322 1443 350 1426 351 4/30/2011 11:36 10.7 1426 352 1487 322 1447 351 1431 351 4/30/2011 11:36 10.6 1431 352 1492 320 1450 351 1437 351 4/30/2011 11:36 10.5 1438 353 1494 320 1453 351 1436 351 4/30/2011 11:36 10.7 1440 353 1499 320 1455 351 1439 351 4/30/2011 11:36 10.7 1441 353 1498 319 1459 350 1444 351 4/30/2011 11:36 10.7 1441 353 1501 319 1460 350 1444 351 4/30/2011 11:36 10.7 1444 353 1502 319 1460 350 1442 352 4/30/2011 11:36 10.7 1445 353 1505 321 1460 349 1444 353 4/30/2011 11:36 10.7 1445 353 1503 322 1454 349 1438 353 4/30/2011 11:36 10.7 1445 353 1502 322 1453 349 1441 353 Quote
Parker_Woodruff Posted May 2, 2011 Report Posted May 2, 2011 Need to know the EGT where the cylinder peaked and how many degrees it was rich or lean in relation to peak. 353 dF is nothing to be owrried about. Quote
bnicolette Posted May 2, 2011 Author Report Posted May 2, 2011 Quote: Parker_Woodruff Need to know the EGT where the cylinder peaked and how many degrees it was rich or lean in relation to peak. 353 dF is nothing to be owrried about. Quote
Barry Posted May 2, 2011 Report Posted May 2, 2011 Well, you've the information on the engine. One reason for flying low is to get out of the way of high winds on the nose. A 40 knot wind at 7000 may only be a 15 knot wind at 3500. Quote
