podair Posted February 20, 2018 Report Posted February 20, 2018 what is this light for, if this is a light? M20F pilot footwell, looks like it is part of the airspeed switch (landing gear safety device, ie don't retract under a certain speed). Quote
rakesb Posted February 20, 2018 Report Posted February 20, 2018 I believe it’s intended to simply illuminate to assist in viewing the fuel selector switch setting (on the floor under the pilot’s feet). 1 Quote
Yetti Posted February 20, 2018 Report Posted February 20, 2018 There is no lettering on the wire so it is not stock Mooney. Quote
ragedracer1977 Posted February 20, 2018 Report Posted February 20, 2018 15 minutes ago, Yetti said: There is no lettering on the wire so it is not stock Mooney. It is. It’s to illuminate the fuel selector. Quote
carusoam Posted February 21, 2018 Report Posted February 21, 2018 I don’t remember anything in the POH detailing the fuel selector light... My M20C had one. I came across it while working on getting panel lights to dim properly... all the panel lights are grounded to a bolt near the fuel selector light. Looks similar to the gear lights on the panel in construction... does it have an iris twist control for dimming? Best regards, -a- Quote
ragedracer1977 Posted February 21, 2018 Report Posted February 21, 2018 9 minutes ago, carusoam said: I don’t remember anything in the POH detailing the fuel selector light... My M20C had one. I came across it while working on getting panel lights to dim properly... all the panel lights are grounded to a bolt near the fuel selector light. Looks similar to the gear lights on the panel in construction... does it have an iris twist control for dimming? Best regards, -a- Yes it does have an iris 1 Quote
ragedracer1977 Posted February 21, 2018 Report Posted February 21, 2018 My POH identifies it. 1 Quote
asaxet Posted February 23, 2018 Report Posted February 23, 2018 Mine has one also.... was wondering.... now Im not... Thx.. Quote
0TreeLemur Posted February 23, 2018 Report Posted February 23, 2018 Mine is really dim even with the iris fully open. Quote
luv737s Posted February 23, 2018 Report Posted February 23, 2018 If the 28 volt bulb is put in instead of the 14 volt it will be dim. Found wrong bulb in my mag compass when I first got it. Don’t know if that’s your problem. mike Quote
HRM Posted February 24, 2018 Report Posted February 24, 2018 On 2/20/2018 at 5:30 AM, rakesb said: I believe it’s intended to simply illuminate to assist in viewing the fuel selector switch setting (on the floor under the pilot’s feet). Yup, that's what it is. See @ragedracer1977 post with the POH excerpt. Quote
Hank Posted February 24, 2018 Report Posted February 24, 2018 Hey, look! My '70 C does too! Now I need to stand on my head and look for it . . . . Quote
Guitarmaster Posted February 24, 2018 Report Posted February 24, 2018 Yeah, those of us with later-model F's just have to Fumble around in the dark. Sent from my XT1585 using Tapatalk 1 Quote
Yetti Posted February 25, 2018 Report Posted February 25, 2018 It's OK I got red panel lights and no one else did, so I am good. Quote
Pictreed Posted February 26, 2018 Report Posted February 26, 2018 Actual panel lights or those hot bullets on the overhead? Quote
Igor_U Posted February 27, 2018 Report Posted February 27, 2018 21 hours ago, Pictreed said: Actual panel lights or those hot bullets on the overhead? If memory serves me well, panel lights were options. These are part of plastic overlays and controlled by rheostat overhead. My '67F has them... Quote
Dream to fly Posted February 27, 2018 Report Posted February 27, 2018 Ha... I found a power source from a socket I had no idea what it was for... Now it powers a 2K watt heater.. LOL Quote
