Boilermonkey Posted August 12, 2017 Report Posted August 12, 2017 THANK YOU GARMIN. Starting to have some fun with the Virb that I won at AirVenture. The camera's altimeter is at times about 100ft off, but the picture is amazing. Win have to connect audio next! https://youtu.be/m0XoRCJ_XcU 1 Quote
PTK Posted August 12, 2017 Report Posted August 12, 2017 1 hour ago, Boilermonkey said: THANK YOU GARMIN. Starting to have some fun with the Virb that I won at AirVenture. The camera's altimeter is at times about 100ft off, but the picture is amazing. Win have to connect audio next! https://youtu.be/m0XoRCJ_XcU What nd filter are you using? What number? Quote
Boilermonkey Posted August 12, 2017 Author Report Posted August 12, 2017 It's the Garmin prop filter 010-12389-16 Quote
carusoam Posted August 12, 2017 Report Posted August 12, 2017 Nice landings... The stall warning comes on as if it were cued. Gonna need a second VIRB to show the alignment with the runway lines from the outside. GPS derived altitude is defintiely not the same as pressure derived altitude. It should match pretty well when the Kohlsman's window is set to the pressure and the pressure is 29.92". Thanks for sharing the video. Best rgeards, -a- 1 Quote
Mooneymite Posted August 12, 2017 Report Posted August 12, 2017 18 minutes ago, carusoam said: GPS derived altitude is defintiely not the same as pressure derived altitude. It should match pretty well when the Kohlsman's window is set to the pressure and the pressure is 29.92". Really? ?? I found this to help complicate things: GPS has transformed how altitude at any spot is measured. GPS uses an ellipsoid coordinate system for both its horizontal and vertical datums. An ellipsoid—or flattened sphere—is used to represent the geometric model of the earth. http://www.esri.com/news/arcuser/0703/geoid1of3.html 2 Quote
carusoam Posted August 12, 2017 Report Posted August 12, 2017 Oooh.... and there is that technical detail too! So, are we getting closer to using GPS derived altitude? ADSB with a WAAS source puts us a bit closer... Just need everybody in the world to get on with the new standard. Set the auto-land system to 'on'. Best regards, -a- Quote
Boilermonkey Posted August 12, 2017 Author Report Posted August 12, 2017 I believe the Garmin Virb Ultra 30 has an atmospheric altimeter. They have a different case for external and internal. The internal one has a hole in the case to allow the pressure to equalize. Quote
