gitmo234 Posted August 1, 2017 Report Posted August 1, 2017 As some of you know I recently acquired a 66 E model. Sunday I flew it from KOWP to 58M which ended up being two stops and about 8 to 8.5 hours of flight time. Prior to flight I checked the oil and it was at 6 quarts. Yesterday I went to the airport to do some pattern work and checked the oil in preflight and it was just a touch below 4. There was some oil below the air intake and down the underside of the engine cowling. I'm wondering if this rate is normal for a long cross country, and maybe I had some venting along the way too. Any thoughts?
MIm20c Posted August 1, 2017 Report Posted August 1, 2017 I don't think you should have a lot of venting when you started with 6 qts. I've been running mine at 6 and have used 2 qts over the last 25 hours. Personally I would not let it drop below 5. How old was the oil when you left on the CC?
PTK Posted August 1, 2017 Report Posted August 1, 2017 50 minutes ago, gitmo234 said: As some of you know I recently acquired a 66 E model. Sunday I flew it from KOWP to 58M which ended up being two stops and about 8 to 8.5 hours of flight time. Prior to flight I checked the oil and it was at 6 quarts. Yesterday I went to the airport to do some pattern work and checked the oil in preflight and it was just a touch below 4. There was some oil below the air intake and down the underside of the engine cowling. I'm wondering if this rate is normal for a long cross country, and maybe I had some venting along the way too. Any thoughts? Check to see what your POH says about oil quantity for extended flight. Starting extended flight with 6 quarts sounds low. I know my POH says 8 qts for extended flight.
gitmo234 Posted August 1, 2017 Author Report Posted August 1, 2017 Thanks, I'll double check all that info. Oil was changed in April but it hasn't flown since then (I bought it in April while I was out of the country). I would expect some longer duration flight to burn some oil.
Bartman Posted August 1, 2017 Report Posted August 1, 2017 My J will definitely stabilize at 6.5 quarts, but will throw out anything more than that. I also use more oil with long climbs and high RPM, but seeing less than 4 quarts demands a good cleaning and inspection. Not sure where the oil leak is, but valve covers, cylinder drain tube connections, case cracks and front crank seals are common.
Bartman Posted August 1, 2017 Report Posted August 1, 2017 Also, if you stopped twice what did it show on the dipstick and how much did you add ?
gitmo234 Posted August 1, 2017 Author Report Posted August 1, 2017 First stop was 6, but that was after 90 minutes only. The second stop it appeared to be 6 or slightly lower, but it was night, and the oil was so clear/new looking that it was hard to tell and we weren't sitting long enough for the oil to collect again to get an accurate reading. It was a very quick refuel, oil check, and get in the air to try and get back before midnight
gitmo234 Posted August 1, 2017 Author Report Posted August 1, 2017 I cant seem to find an entry on extended flight. I did find the engine manual itself which says the oil consumption is under the max allowable, but that's not entirely helpful either.
Brian Scranton Posted August 1, 2017 Report Posted August 1, 2017 I've been told that if a plane sits a few inches nose high when parked it can influence the dip stick measurement by a full quart...sometimes the ramps we park on are not so level. In my F, I fly with 6 and burn about a quart every 4 hours (beginning ~12 hours after the oil change) on long flights, long climbs, high RPM, etc.
gitmo234 Posted August 1, 2017 Author Report Posted August 1, 2017 1 minute ago, Brian Scranton said: I've been told that if a plane sits a few inches nose high when parked it can influence the dip stick measurement by a full quart...sometimes the ramps we park on are not so level. In my F, I fly with 6 and burn about a quart every 4 hours (beginning ~12 hours after the oil change) on long flights, long climbs, high RPM, etc. I could definitely see that being a problem. I also have one cylinder with <100 hours on it and one with about 110 hours.
211º Posted August 1, 2017 Report Posted August 1, 2017 In my F, I fly with 6 and burn about a quart every 4 hours (beginning ~12 hours after the oil change) on long flights, long climbs, high RPM, etc. About the same here, but another 66E. If I fill to 8 qts after an oil change, it blows out or get "used" filling the additional hoses to the relocated oil filter faster. Then settles down around the 6 qt level.
N201MKTurbo Posted August 1, 2017 Report Posted August 1, 2017 If you leaked 2 quarts in a few hours of flying, your whole plane would be dripping with oil from nose to tail. If it used that much oil it burned it.
gitmo234 Posted August 1, 2017 Author Report Posted August 1, 2017 10 minutes ago, 211º said: About the same here, but another 66E. If I fill to 8 qts after an oil change, it blows out or get "used" filling the additional hoses to the relocated oil filter faster. Then settles down around the 6 qt level. This could be part of the case. Oil was changed and it hasn't been run since until I started it up for the cross country
Brian Scranton Posted August 1, 2017 Report Posted August 1, 2017 One unanswered question: how old is your oil? Before 12-15 hours, I don't burn anything of notice. But as the oil gets dirty (or breakdown--which doesn't really happen) I begin to use more (like I said, about a qt per 4-6 hours).
Godfather Posted August 1, 2017 Report Posted August 1, 2017 4 hours ago, Brian Scranton said: One unanswered question: how old is your oil? Before 12-15 hours, I don't burn anything of notice. But as the oil gets dirty (or breakdown--which doesn't really happen) I begin to use more (like I said, about a qt per 4-6 hours). Oil was changed in April and not flown so ~0 hrs...however, I completely agree that oil usage goes up as the hrs increase 0-25 vs 25+.
Yetti Posted August 1, 2017 Report Posted August 1, 2017 Run it. Watch it. I dont think you have enough history with the engine. See the thread about 2500 on climb out
Hank Posted August 2, 2017 Report Posted August 2, 2017 46 minutes ago, Godfather said: Oil was changed in April and not flown so ~0 hrs...however, I completely agree that oil usage goes up as the hrs increase 0-25 vs 25+. When I change oil, I put on a new filter and add 7 qts., then take a test flight and check for leaks. It will read just above 6 for a few hours, and generally takes 10-12 hours before I add the first quart (but I may add 1/2 qt before a long trip). Long climbs to altitude and cruising at 2500 does increase oil usage above short, low burger runs at 2300 . . . .
gitmo234 Posted August 2, 2017 Author Report Posted August 2, 2017 2 hours ago, Yetti said: Run it. Watch it. I dont think you have enough history with the engine. See the thread about 2500 on climb out I’m thinking this is the answer for now. i can’t find the thread you mentioned. Next week I’m due to start making my commute to DC by air when VFR. I’ll whipe it down and observe
Guest paulie Posted August 2, 2017 Report Posted August 2, 2017 Every engine has it's own level. People fill up to eight and think it's burning oil. Let it run down to 5, fly it and see if it stabilizes at that level. If so fill to six and repeat. If stable try seven. My io-360 likes to be at 6.5, any more and it blows it out the breather.
carusoam Posted August 2, 2017 Report Posted August 2, 2017 Summary: 1) measuring the oil level takes being level. Done after sitting a day... 1a) oil hides in the oil cooler, and prop, and other places... 2) over 6qts, high probability of being pushed out the case vent. 3) high power, for a long climb, and high angle of climb aids the oil pushing out the vent. 4) oil that gets burned leaves a trail in the exhaust pipe. 5) oil that gets vented leaves a trail on the belly. 6) There is a list of rubber bits that can be checked for leaks. 7) rubber bit leaks leave a trail all over the inside of the cowl. 8) case cracks leak oil. Something that gets looked into after Steps 1 - 7 have been exhausted... 9) Long cruise itself doesn't use up much oil as discussed. It lacks the characteristics of high power, high angle, and high temperature (CHT and oilT) 10) Do a lot of measuring to get to know your plane. Best regards, -a-
Skates97 Posted August 2, 2017 Report Posted August 2, 2017 23 minutes ago, gitmo234 said: I’m thinking this is the answer for now. i can’t find the thread you mentioned. Next week I’m due to start making my commute to DC by air when VFR. I’ll whipe it down and observe Here it is.
gitmo234 Posted August 2, 2017 Author Report Posted August 2, 2017 8 hours ago, carusoam said: Summary: 1) measuring the oil level takes being level. Done after sitting a day... 1a) oil hides in the oil cooler, and prop, and other places... 2) over 6qts, high probability of being pushed out the case vent. 3) high power, for a long climb, and high angle of climb aids the oil pushing out the vent. 4) oil that gets burned leaves a trail in the exhaust pipe. 5) oil that gets vented leaves a trail on the belly. 6) There is a list of rubber bits that can be checked for leaks. 7) rubber bit leaks leave a trail all over the inside of the cowl. 8) case cracks leak oil. Something that gets looked into after Steps 1 - 7 have been exhausted... 9) Long cruise itself doesn't use up much oil as discussed. It lacks the characteristics of high power, high angle, and high temperature (CHT and oilT) 10) Do a lot of measuring to get to know your plane. Best regards, -a- Great, thanks. Lots to look at. This could be a combo of a lot. New oil change after sitting awhile + not being run after and sitting awhile + not being level + high angle of attack. We were climbing out at 25/2500 so lower setting but at 110 mph IAS I was getting about 1k feet per minute sometimes. My plan is to wipe it down, run it some more, take it easy on climb AOA, check it a while and develop the actual "pattern of life" or "pattern of oil" before I get too worried. For good measure I may remove a cowling just to make sure it doesn't look like an engine murder scene.
carusoam Posted August 2, 2017 Report Posted August 2, 2017 Huge benefit of having the side cheeks that come off the cowling... 1) each cylinder head has an oil return line with so many aged hose clamps... 2) each rocker box cover has a gasket that was once cork... 3) airspeed has a tendency to really move an oil drip around... including out the front of the cowl. Fun stuff... Best regards, -a-
