Stephen Posted May 30, 2017 Report Posted May 30, 2017 Hi Guys, M20F Cruise Performance Capture.xlsx Here is a spreadsheet I used to capture performance vs the MAPA M20F stock evaluation( see link at bottom of posting). If you want to compare your ride vs a stock F fly the 3 GPS boxes, get the OAT, fill the data and post for comparison. I will post mine (data is at home) for comparison. This is also good to do pre-rigging change for comparison basis. When you are flying the GPS box, a steady hand or even better an auto-pilot with altitude hold is your friend. Also, note separate cells to capture RAM air OFF vs ON. Link to MAPA M20F evaluation: M20F_Evaluation_Report.html Quote
