gsengle Posted August 26, 2017 Report Posted August 26, 2017 I'm starting to see that, in a big way. There might be a diamond in the rough here or there but it's starting to seem like "buy once cry once" really does apply here. Personally I believe the well loved machines are the bargains, because those airplanes aren't going for as much as they deserve above bluebook!Sent from my iPhone using Tapatalk Quote
Firebird2xc Posted August 26, 2017 Report Posted August 26, 2017 1 hour ago, gsengle said: Personally I believe the well loved machines are the bargains, because those airplanes aren't going for as much as they deserve above bluebook! Sent from my iPhone using Tapatalk Define 'deserve'. Sentiment doesn't mean much to me when somebody's trying to use it to steal my AMUs. There's a lot of people out there trying to get all of the money they spent on upgrades to an airplane back when they sell it. Meanwhile, their expensive gizmo isn't shiny or even relevant anymore- or at the very least depreciated. I see airplanes with an ancient stack and a shiny new cheap coat of paint being marketed at well over Vref and think they'll just find a sucker. I see planes where the owner obviously hasn't kept up maintenance, is probably upside down on the loan, and thinks he can find a sucker to bail him out, etc. As for 'well loved', an expensive panel upgrade means spit to me when I open the tail access panel and see control rods crawling with corrosion. Airplane shopping is worse than house hunting. Quote
gsxrpilot Posted August 26, 2017 Report Posted August 26, 2017 Mooneys naturally fall in to three categories, short, mid, long. And they are also three different categories of cost as well. The short bodies are the ultimate certificated, traveling airplane in the $40K to $60K range. The mid bodies are the best traveling machines in the $100K to $200K range. And the long bodies for the "if you have to ask, you can't afford it" crowd. The mid-bodies are also the sweet spot for speed and efficiency. And the pinnacle of that pursuit is the normally aspirated M20J 205 and in the turbo category, the M20K Encore. Both of these models are rare and so this, very well cared for M20J 205 should be top of the list for anyone in the market for a mid-body normally aspirated Mooney. If you're gonna put money into an airplane post purchase... and don't lie, we all do... you can't start with a better platform than the M20J 205, or the M20K 252. I'm about to talk myself into buying it just to have the matched set ;-) 1 1 Quote
Lowbid Posted August 26, 2017 Report Posted August 26, 2017 My only concern is the make-up oil consumption. I believe one of the Blackstone analysis' showed 8 quarts of make-up oil? My C uses 1 quart between changes. 8 seems very high, but maybe I'm spoiled. 1 Quote
gsengle Posted August 26, 2017 Report Posted August 26, 2017 Define 'deserve'. Sentiment doesn't mean much to me when somebody's trying to use it to steal my AMUs. There's a lot of people out there trying to get all of the money they spent on upgrades to an airplane back when they sell it. Meanwhile, their expensive gizmo isn't shiny or even relevant anymore- or at the very least depreciated. I see airplanes with an ancient stack and a shiny new cheap coat of paint being marketed at well over Vref and think they'll just find a sucker. I see planes where the owner obviously hasn't kept up maintenance, is probably upside down on the loan, and thinks he can find a sucker to bail him out, etc. As for 'well loved', an expensive panel upgrade means spit to me when I open the tail access panel and see control rods crawling with corrosion. Airplane shopping is worse than house hunting. Well loved means well maintained, not lipstick on a pig. Well loved planes don't command as much money as they should imho. So you're better off buying one for a little more than buying a "bargain" bird where you'll give back your "savings" in maintenance pretty darn quick.Sent from my iPhone using Tapatalk 3 Quote
gsxrpilot Posted August 26, 2017 Report Posted August 26, 2017 4 minutes ago, gsengle said: Well loved means well maintained, not lipstick on a pig. Well loved planes don't command as much money as they should imho. So you're better off buying one for a little more than buying a "bargain" bird where you'll give back your "savings" in maintenance pretty darn quick. Yep, I've got a list of members who thought they had found a bargain. 2 Quote
Firebird2xc Posted August 26, 2017 Report Posted August 26, 2017 4 minutes ago, gsengle said: Well loved means well maintained, not lipstick on a pig. Well loved planes don't command as much money as they should imho. So you're better off buying one for a little more than buying a "bargain" bird where you'll give back your "savings" in maintenance pretty darn quick. Sent from my iPhone using Tapatalk Fair enough. Any key points to look for that really show this? Being a forensic detective to figure out if an airplane has been cared for or not is getting old. Quote
gsengle Posted August 26, 2017 Report Posted August 26, 2017 Fair enough. Any key points to look for that really show this? Being a forensic detective to figure out if an airplane has been cared for or not is getting old. It's hard - best bet is to know the owner and their reputation as well as the shop that did the maintenance. Sometimes just how clean the engine is can be a tell tale indication (not on my bird)... meticulous records are a good sign too.When I bought my two planes I flew with the owners to gauge their personalities too and how they flew the aircraft. I've had good luck.Sent from my iPhone using Tapatalk 1 Quote
gsxrpilot Posted August 26, 2017 Report Posted August 26, 2017 I look for a bird that gets a lot of use. Heavy usage will result in little things breaking, which is normal. I then look to see how those little things have been repaired. Is there a lot of duct tape, zip ties, and HomeDepot hardware? Or are things fixed right, with correct parts, and log entries. You can often see this from a quick look around the plane, sitting in the cockpit, and a quick scan of the logs. 1 Quote
Firebird2xc Posted August 26, 2017 Report Posted August 26, 2017 10 minutes ago, gsengle said: It's hard - best bet is to know the owner and their reputation as well as the shop that did the maintenance. Sometimes just how clean the engine is can be a tell tale indication (not on my bird)... meticulous records are a good sign too. When I bought my two planes I flew with the owners to gauge their personalities too and how they flew the aircraft. I've had good luck. Sent from my iPhone using Tapatalk 10 minutes ago, gsxrpilot said: I look for a bird that gets a lot of use. Heavy usage will result in little things breaking, which is normal. I then look to see how those little things have been repaired. Is there a lot of duct tape, zip ties, and HomeDepot hardware? Or are things fixed right, with correct parts, and log entries. You can often see this from a quick look around the plane, sitting in the cockpit, and a quick scan of the logs. I appreciate the insight here, guys. You actually just vindicated a few points where I was feeling a little over-suspicious. 2 Quote
LuvFlying Posted August 26, 2017 Author Report Posted August 26, 2017 53 minutes ago, Lowbid said: My only concern is the make-up oil consumption. I believe one of the Blackstone analysis' showed 8 quarts of make-up oil? My C uses 1 quart between changes. 8 seems very high, but maybe I'm spoiled. It had a leak from a hose (or something, IIRC right now) that was fixed during annual. It was an obvious leak (oily belly) that I was aware of and was on the squawk list for annual. Since then, it returned back to normal. Quote
Firebird2xc Posted August 26, 2017 Report Posted August 26, 2017 16 minutes ago, LuvFlying said: It had a leak from a hose (or something, IIRC right now) that was fixed during annual. It was an obvious leak (oily belly) that I was aware of and was on the squawk list for annual. Since then, it returned back to normal. Can you approximate what your normal oil consumption rate is? Quote
Godfather Posted August 26, 2017 Report Posted August 26, 2017 52 minutes ago, gsengle said: Well loved means well maintained, not lipstick on a pig. Well loved planes don't command as much money as they should imho. So you're better off buying one for a little more than buying a "bargain" bird where you'll give back your "savings" in maintenance pretty darn quick. Sent from my iPhone using Tapatalk People give the same value on engine times if the overhaul is 30 years old and the bird is flying 30 hrs a year vs one that is recent, flying 150 hrs a year. I'd much rather buy a plane that has been in the air a lot over the past decade and has good maintenance to back that up. 2 Quote
gsxrpilot Posted August 26, 2017 Report Posted August 26, 2017 6 minutes ago, Godfather said: People give the same value on engine times if the overhaul is 30 years old and the bird is flying 30 hrs a year vs one that is recent, flying 150 hrs a year. I'd much rather buy a plane that has been in the air a lot over the past decade and has good maintenance to back that up. Yes, and to add to that, I'd give more value to an engine in an airplane with an engine monitor. And while I'm evaluating the owner, I'd be checking to see if he/she knows how to read/use the engine monitor. 2 Quote
Firebird2xc Posted August 26, 2017 Report Posted August 26, 2017 23 minutes ago, gsxrpilot said: Yes, and to add to that, I'd give more value to an engine in an airplane with an engine monitor. And while I'm evaluating the owner, I'd be checking to see if he/she knows how to read/use the engine monitor. Well said, sir. Once I realized data trend tracking was available with the new JPI monitors, for example, I decided I won't own a plane without one. 1 Quote
rbridges Posted August 26, 2017 Report Posted August 26, 2017 2 hours ago, gsengle said: It's hard - best bet is to know the owner and their reputation as well as the shop that did the maintenance. Sometimes just how clean the engine is can be a tell tale indication (not on my bird)... meticulous records are a good sign too. When I bought my two planes I flew with the owners to gauge their personalities too and how they flew the aircraft. I've had good luck. Sent from my iPhone using Tapatalk In my one and only plane purchase, I dealt with a guy that really appeared genuine. Took time to explain things, and he made several comments that made me realize he looked over the plane carefully. He also had his logs and manuals organized extremely well. Out of ignorance, I didn't get a thorough pre-purchase, but everything went well. 2 Quote
GaryP1007 Posted August 29, 2017 Report Posted August 29, 2017 wow....what a beauty. Gives me a good sense of what I can get for the $$ when I shop next spring. Quote
LuvFlying Posted September 15, 2017 Author Report Posted September 15, 2017 SOLD Oh... and as such... I say goodby to this wonderful community. You folks are awesome! 3 Quote
gsxrpilot Posted September 15, 2017 Report Posted September 15, 2017 A lot of folks on this board missed out on a great bird. 2 Quote
Firebird2xc Posted September 15, 2017 Report Posted September 15, 2017 46 minutes ago, gsxrpilot said: A lot of folks on this board missed out on a great bird. So long as somebody gives the airplane a good new home, eh? I scraped up the extra cash to make a possible offer but was out of the country then locked down under Irma. C'est la vie- sometimes the timing just isn't there. Quote
carusoam Posted July 9, 2018 Report Posted July 9, 2018 On 9/15/2017 at 5:01 PM, LuvFlying said: SOLD Oh... and as such... I say goodby to this wonderful community. You folks are awesome! Dooley, Unfortunately, They didn’t make two of this one.... (this is a few posts up from here) Best regards, -a- Quote
dooleypster Posted July 9, 2018 Report Posted July 9, 2018 It shows this post as 15 hrs old. Is this bird still for sale? Quote
steingar Posted July 9, 2018 Report Posted July 9, 2018 Congrats to the OP, that looked like a very well maintained plane. The highest priority item on my list is always did the owner take good car of the airplane? Is it clean? Where did it live? Was it hangared? What got done to it? A well cared for aircraft will give you fewer problems than one that was just flown and ignored. I still don't get this whole engine monitor thing. My aircraft has a plain-jane 0360 Lycosaurous. There's been one under its hood since 1962, for well over 4000 flight hours. What's an engine monitor going to do for me again? Quote
