jkgyr52 Posted March 25, 2017 Report Posted March 25, 2017 I am upgrading my two year old JPI EDM 830 system to a EDM 900 Primary. (My Mooney 262 has the TSIO360MB4B engine). The system for sale includes everything available for monitoring a turbocharged engine - EGT 6 Probes, CHT 6 Probes, 1 TIT Probe, Volts, Shock Cooling, LOP/ROP JPI Exclusive Leaning Mode, Fuel Flow (USED, Remaining, GPH Endurance, GPS Destination), 201 fuel flow transducer - fuel pump type, RPM, MAP, Oil Temperature/Pressure, OAT probe,% HP, Power Connector, All required harnesses, EZTrendsData recording, 100 hrs Download USB 1 GB Memory Stick, Selectable Positions for Linear gauges, Manual and all other paperwork. The wiring harness will be new and untrimmed. A new unit with all these options is $2660 at Spruce plus tax/shipping. I would like to get $ 1800, shipping included. Check, cash, cc accepted. Thanks, Jeff 208-720-2506 flyingfalconpllc@gmail.com
Sams Posted March 25, 2017 Report Posted March 25, 2017 I am upgrading my two year old JPI EDM 830 system to a EDM 900 Primary. (My Mooney 262 has the TSIO360MB4B engine). The system for sale includes everything available for monitoring a turbocharged engine - EGT 6 Probes, CHT 6 Probes, 1 TIT Probe, Volts, Shock Cooling, LOP/ROP JPI Exclusive Leaning Mode, Fuel Flow (USED, Remaining, GPH Endurance, GPS Destination), 201 fuel flow transducer - fuel pump type, RPM, MAP, Oil Temperature/Pressure, OAT probe,% HP, Power Connector, All required harnesses, EZTrendsData recording, 100 hrs Download USB 1 GB Memory Stick, Selectable Positions for Linear gauges, Manual and all other paperwork. The wiring harness will be new and untrimmed. A new unit with all these options is $2660 at Spruce plus tax/shipping. I would like to get $ 1800, shipping included. Check, cash, cc accepted. Thanks, Jeff 208-720-2506 flyingfalconpllc@gmail.com You should have an email. Gesendet von iPad mit Tapatalk
carusoam Posted March 25, 2017 Report Posted March 25, 2017 And mention where you are... expensive and useful things like this can gain interest if a potential buyer can fly over to see it. Best regards, -a-
jkgyr52 Posted March 26, 2017 Author Report Posted March 26, 2017 N57785 is in Evanston, WY for OH engine and prop. 1
