eaglebkh Posted December 20, 2010 Report Posted December 20, 2010 At a recent AOPA/FAAST Seminar, the presentor threw out some trivia about how the FAR's require owners to log any Nav (GPS) database updates in the airframe log. He even showed us the relevant FAR (I can't remember which section). I had never heard of this before, and have obviously not been logging such updates. So are any of you aware of this, and do you log updates? Quote
jlunseth Posted December 20, 2010 Report Posted December 20, 2010 Is it possible you didn't understand him correctly? To my knowledge there is no requirement to log database updates. However, if there is a firmware update, that is a different thing. A firmware update changes the software that runs the nav device and it apparently needs to be done by an A&P, at least that is what Garmin requires. It would not surprise me if the A&P logs the firmware update. Never heard of logging a database update, the device itself records and displays the currency date of the database, so why log it also? Quote
FlyDave Posted December 20, 2010 Report Posted December 20, 2010 I started a thread on this earlier this year: http://mooneyspace.com/index.cfm?mainaction=posts&forumid=4&threadid=1295 I keep a record of 430 DB updates in my fuel/oil log in the airplane. I also have a white board in my hangar that I make entries on. Quote
mooney231 Posted December 20, 2010 Report Posted December 20, 2010 Quote: eaglebkh At a recent AOPA/FAAST Seminar, the presentor threw out some trivia about how the FAR's require owners to log any Nav (GPS) database updates in the airframe log. He even showed us the relevant FAR (I can't remember which section). I had never heard of this before, and have obviously not been logging such updates. So are any of you aware of this, and do you log updates? Quote
eaglebkh Posted December 20, 2010 Author Report Posted December 20, 2010 Quote: jlunseth Is it possible you didn't understand him correctly? Quote
tony Posted December 20, 2010 Report Posted December 20, 2010 I believe the FAR says that you must keep a maintenance record. It doesn’t say anything about keeping a logbook. When you power the unit up, you see the maintenance record. Quote
danb35 Posted December 20, 2010 Report Posted December 20, 2010 Quote: tony I believe the FAR says that you must keep a maintenance record. It doesn’t say anything about keeping a logbook. When you power the unit up, you see the maintenance record. Quote
tony Posted December 20, 2010 Report Posted December 20, 2010 It’s a life limited part with an expiration date that has a mandatory replacement and you are following the installation manual for continued airworthiness. The electronic record keeping shows the expiration date. Should fall under 43.10 Quote
kortopates Posted December 20, 2010 Report Posted December 20, 2010 I've enjoyed monitoring the site, but haven't posted till now and thought I would add my two cents to this thread. Jason spelled it out very well that updating avionics DB is "maintenance" and showed the requirements by which "all" maintenance must be logged. Danb35 explained exactly why the the units expiration date does not qualify as a maintenance record spelled out in 43.9 which requires 3 to 4 pieces of information in the maintenance record and the expiration date of the database is not one of them. Complain all you want about the silliness of this but its clearly spelled out and its so very simple to properly log all your database updates in your VOR Test log. That's what I've been doing with the 3 databases I have, including my Jepp charts DB which is updated every 14 days. Although a pain perhaps, not a big deal. Quote
mooney231 Posted December 20, 2010 Report Posted December 20, 2010 Quote: tony It’s a life limited part with an expiration date that has a mandatory replacement and you are following the installation manual for continued airworthiness. The electronic record keeping shows the expiration date. Should fall under 43.10 Quote
Jeff_S Posted December 21, 2010 Report Posted December 21, 2010 I went to that same seminar in Atlanta and heard the same instruction. I wonder, if everything that was *supposed* to be logged on a 20+ year old airplane actually had been logged somewhere, what size room that would fill up? No disputing the regs, but this one seems like the technology curve got ahead of the reg writers. As noted above, clearly the unit itself will tell an inspector whether or not the database is current, and the mere fact that it powers up will show that it's functional (after self tests). So who cares what's written down in a book somewhere? Quote
mooney231 Posted December 21, 2010 Report Posted December 21, 2010 Quote: Jeff_S I went to that same seminar in Atlanta and heard the same instruction. I wonder, if everything that was *supposed* to be logged on a 20+ year old airplane actually had been logged somewhere, what size room that would fill up? No disputing the regs, but this one seems like the technology curve got ahead of the reg writers. As noted above, clearly the unit itself will tell an inspector whether or not the database is current, and the mere fact that it powers up will show that it's functional (after self tests). So who cares what's written down in a book somewhere? Quote
eaglebkh Posted December 21, 2010 Author Report Posted December 21, 2010 Since updating the database is considered preventative maintanence, is it required to be logged in the airframe log, or just a separate log like the VOR check. Since a VOR check is not preventative maintanence (nothing is about the airplane changed because of the VOR check), I'm thinking it's okay to log it on a separate log, but not the database log? Quote
GeorgePerry Posted December 21, 2010 Report Posted December 21, 2010 I think we all can agree that some rule are just stupid and serve no real purpose. This is one of them. My question to the group is how does an individual address a rule change with the FAA. I never seen nor heard of a "proposed rule change" form or any formalized way joe average can make a recommnedation for a change. thoughts from the group... Quote
danb35 Posted December 21, 2010 Report Posted December 21, 2010 Quote: eaglebkh Since updating the database is considered preventative maintanence, is it required to be logged in the airframe log, or just a separate log like the VOR check. Quote
danb35 Posted December 21, 2010 Report Posted December 21, 2010 Quote: GeorgePerry My question to the group is how does an individual address a rule change with the FAA. Quote
DonMuncy Posted December 21, 2010 Report Posted December 21, 2010 I keep a log separate from the airframe log (so as to not clutter up my logbook), along with my VOR checks, on the attached form. It may be overkill, but it is easy and I think it complies with the regs. Don Quote
DonMuncy Posted December 21, 2010 Report Posted December 21, 2010 Apparently my attachment didn't attach. Here is the form. Don On the dates set out below, I, -----------, holder of ----------- Pilot Certificate number -----------, updated the Air Traffic Control navigational software data bases (Jeppesen aviation database) in the Garmin GNS 430 Global Positioning System installed in Aircraft N----------, pursuant to the instructions provided by Garmin International, Inc and Jeppesen aviation database services, under the authority of 14 CFR Section 43.3, and Section A43.1 © (32), Federal Aviation Regulations. After the update, and prior to flight, an operational check was successfully completed and the aircraft was approved for return to service. Date _________________ Signature _______________________________ Date _________________ Signature _______________________________ Quote
