kelty Posted October 4, 2016 Report Share Posted October 4, 2016 Hi all. My trim switch just stopped working. It will still trim nose down and disconnect the Century IIIb, but it wont trim nose up anymore. Thats why im thinking its the switch that has gone bad. I pulled the switch out and it looks fine, and used some contact cleaner before reinstalling it, but no luck. Not the greatest picture of the switch, but does anyone know the part number, couldn't find it, and where to get one. Thanks Kelty Quote Link to comment Share on other sites More sharing options...
bradp Posted October 5, 2016 Report Share Posted October 5, 2016 Your glare shield light connector seems to be pinched under between the glare shield and the panel btw... Quote Link to comment Share on other sites More sharing options...
Piloto Posted October 5, 2016 Report Share Posted October 5, 2016 The paddle of the trim switch is a cam that activates and deactivate the switches. In my case I found the cam to be worn out. I added a drop of fiberglass resin and sanded it to shape. It has worked very well for the last 4 years. This is a delicate job that requires a magnifying glass lamp and jewelers tools. José Quote Link to comment Share on other sites More sharing options...
laytonl Posted October 5, 2016 Report Share Posted October 5, 2016 Is this the trim switch that has three small switches ganged together? If so, Mouser has them. You should be able to separate the switches and find a part number. Lee Quote Link to comment Share on other sites More sharing options...
231MJ Posted December 11, 2016 Report Share Posted December 11, 2016 I have the same problem with mine. I thought it might be the relay but replacing it did not fix the problem. I suspect a new switch from Century costs a small fortune. Anyone have alternate idea than the fiberglass resin trick? Spruce has a similar trim switch for $250 (http://www.aircraftspruce.com/catalog/elpages/trimSwitches2.php?clickkey=5126), Anyone have experience with this switch? It looks so similar I'm tempted to try it but I have not found a wiring diagram for the system - anyone have access to the diagram? Thanks 231MJ Quote Link to comment Share on other sites More sharing options...
rcwagner Posted January 6, 2020 Report Share Posted January 6, 2020 I don't think the Aircraft Spruce switch will work. The Mooney switch also has a circuit that engages the clutch in the pitch trim servo. Activating the switch includes running the servo motor in a particular direction and engages the clutch to the drive sprocket. I am sure they are VERY pricey. Quote Link to comment Share on other sites More sharing options...
rcwagner Posted January 6, 2020 Report Share Posted January 6, 2020 Does anyone just have manual trim without the magic trim button? Quote Link to comment Share on other sites More sharing options...
khedrei Posted January 8, 2020 Report Share Posted January 8, 2020 I have what I believe to be the same/similar switch from my K. I think it's a mooney switch. Needed to replace with garmin switch with the new auto pilot. It worked fine when removed. Unfortunately I wouldnt be able to get you a part number or sell it to you for at least a couple weeks next time I go to the shop when its done. But you can keep it in mind. I'd sell for a very reasonable price. Quote Link to comment Share on other sites More sharing options...
kommers Posted January 8, 2020 Report Share Posted January 8, 2020 I had this issue for about a year in my 20J and my mechanic was losing his last hair trying to figure it out. Switch worked intermittently. Sometimes, it worked only to bring the nose down, but not up, sometimes, it would not activate at all. The reason was the pinched cable in the area of glareshield. One of our brothers in Mooneyhood already mentioned that in his post earlier Quote Link to comment Share on other sites More sharing options...
