Oscar Avalle Posted June 2, 2016 Report Posted June 2, 2016 For the last month flying has been not so great... work, weather, family not much time to use my Mooney. So I am taking advantage of the downtime to perform some work...In particualr an ARI cowling (hopefully the CHT will go down with better airflow..). But there is one gremlin that bothers me and that I can not find the solution to the problem. I replaced my Fuel Gauges with an Aerospace Logic Fuel Gauge. Easy to install, but there is one huge problem that makes it nearly useless. So may be somebody can give me an idea what may be going on. When I turn on the master switch the fuel indications are right on mark. However, once I turn on the avionics switch the fuel indications go down by 10 gallons on both tanks... Any idea what may be going on? Grounding? connections... Help!! Quote
carusoam Posted June 2, 2016 Report Posted June 2, 2016 I think we have a contact from CIES around here somewhere... Looking.... Found it. Best regards, -a- Quote
Oscar Avalle Posted June 10, 2016 Author Report Posted June 10, 2016 Thank you. I talked to aerospace logic and they said that most likely a grounding may be off. So now need to check. Quote
NotarPilot Posted November 27, 2016 Report Posted November 27, 2016 On 6/10/2016 at 11:32 AM, Oscar Avalle said: Thank you. I talked to aerospace logic and they said that most likely a grounding may be off. So now need to check. Did this get fixed Oscar? Quote
Oscar Avalle Posted November 27, 2016 Author Report Posted November 27, 2016 Yes, it was resolved. It was a grounding issue. 1 Quote
