Search on headrests.  You will find interesting things about automotive ones that work and how to get them to match your airplane's interior with proper flame rating....
All good news,
  • 2 weeks later...
Don't both looking for original ones, just make them directly.
They were nothing more that a bent U shaped hollow tube (I am sure you could use solid as well) that fit into the 2 holes in the upper part of the seat back and held the headrest by a pocket in the rear of the head rest.
John Breda
I put headrests in my plane.  I regret it.  After buying different seats, having them re-upholstered and installed what have I got?  A headrest that really is NOT functional.  Your head doesn't use it as designed.  They raise the seat-back height making "reaches" into the backseat/baggage area more difficult.  Unless you are going to modify (NOT have straight mounts) the headrest to be forward/have capability to angle forward they are functionally worthless.  Sit in a vintage bird with them and try them.
Waste of time and money...
I could see the back ones with the seat reclined being good for sleeping.   I put none of mine back in on the redo.   Some day I may do the ones for the back...
Thanks for posting this.  I was considering it but not now.
Is it not true ;The headrest adds weight and indirectly creates a less efficient plane. I could make a stretch and say they will slow you down.
An anti-speed mod!
Of course, by that rationale, I should stop drinking beer.  And I don't really see that happening.
