<deleted> before I piss off a fellow Mooney driver.
Edited by 22 others
Deleted a captain obvious response that was not helpful
Prior to serial number 2342, Mooneys did not have a push to start feature on their ignition switches, which means that in the turn-to-start position the starter was energized simultaneously with the shower of sparks.  The only problem with this was if you wanted to hand-prop your airplane.
The switch in question would allow you to not engage the starter, but still energize the shower of sparks, for hand propping.
Look under "Cold weather starting" in the attached picture:
Learn something new every day.  However, it seems to me that by the time you remove and reinstall the panels to flip the switch you could have gotten a jump start, in most cases.  Anyone have much luck hand propping a Mooney with shower of sparks?
Yes, my first M20C back when it was brand new to me back in 1992.  Worked well.
No, I will never do it again.
The amount of effort needed to turn the prop through the compression puts the average Mooney pilot incredibly close to the prop.  Doing it singlehandedly could be dangerous.  Without somebody to hold the key, would it work very well?
It is in the category of too easy to make a big mistake.  From Not setting the throttle properly to the tail tie down rope is old and it breaks.  Standing in front of a runaway Mooney would be quite scary.
watching somebody hand prop a Cub is interesting in comparison.  They flip the prop through as if there is barely any compression.
It definitely requires 2 people, one to hold the key to start to energize the shower of sparks / ground the right mag / advance the left mag and the other person to swing the prop.  I had a flight instructor hold the key to start while I spun the prop.
I was too young and felt too invulnerable to realize I was supposed to be scared, hence I'll never do it again.
Interesting find. My first thought was that it was an anti-theft device but that didn't make much sense. Mooneyspace wins again.
If the battery is dead enough no shower of sparks either.:(
No I will not hand prop a 200HP Lycoming.  Can it be done sure but not by me.  JMHO
Good idea to prevent unauthorized use of the airplane.
