Help,
Anyone had to fix a TKS stall strip that was detaching?  I'm waiting to hear back from Mooney, but I'm sure someone here has had to deal with this?  (its hard to search for TKS here, because you can't search for three character search terms)
Here is a photo.  Is this a big deal or an easy fix?
thanks,
Greg
post-8040-0-96528900-1436796430_thumb.jp
Cool - thanks.
Also, Mooney got back to me blazingly quickly, thanks Stacey!  I'm attaching the procedure - the Redux 420 is no longer available, you use CS3204-B2 sealer.  And I should be very very happy that I didn't lose the $1000+ strip in flight...
Greg
TKS Stall Trigger Installation.pdf
I just had that repair done at CAV at New Century (Kansas City).  The original glue dries out.  CAV knows what to use- PRC product.  They put out a letter which explains the procedure so others can do this in the field.  Do not lose the strip replacements are $800.00.  If you break the little tube feeding the strip you will have to replace the panel.  I taped mine in place for the trip.  Don't let just anyone mess with this a screwup could really get costly.
