You should have a digital vaccuum guage at the upper left spot of your pannel near the fuel guages.
The early Ovations (pre-digital days) have a vac gauge, mechanical needle...
Mine is mounted below the co pilot instrument panel... Looks like an after thought.
Digital days??? The 70s and 80s were the digital number days. The FAA just discovered them in 2000.
In '94, even my digital gauges have analog displays. Similar to the Corvette of its time...
The rpm needle clicks up to the next position. There will be no 2699rpm on my gauge...
