Mckipper Posted June 8, 2013 Report Posted June 8, 2013 I have a habit of gently lifting the stall warning tab as I walk away from the plane - stall horn is loud enough that if the Master is on, I will hear it. i have a clip on my airplane keys, when I preflight and remove the pitot cover, I clip it to the keys. That way, I can easily see the keys on the glare screen when moving the plane or prop, and when I do my run ups and vital actions, I can verify pitot cover off with a glance at the keys, Also always to a check of the cabin lights - have that shirt ....
PTK Posted June 9, 2013 Report Posted June 9, 2013 I also lock the baggage door. What I also do after landing and clear of the active, is set flaps to TO position and leave them there until next time. iow I dont retract them fully only to set them to TO next time. I figure over time it should help the motor by saving cycles. It also facilitates preflight inspection. Does anyone else do this? (...no, I haven't been able to figure out how to save gear motor cycles yet!)
tomn Posted June 9, 2013 Report Posted June 9, 2013 I have a gear warning system - gives me a audible "check gear" in my headset if the gear is up and the rpm drops below about 1600. When I begin my descent, I will quickly pull the trottle back to make sure I get the warning to verify the alert is operational. Its good to check the system that is checking you...
Dan Brown Posted June 9, 2013 Report Posted June 9, 2013 Just one of my many "routines": - If I'm taking passengers (outside my CFI or a pilot friend) I familize them with my flying club clubhouse (or FBO) after I file the flight plan. I then have them wait INSIDE the flying club while I perform the whole preflight, so that the plane and I are fully "ready to go." THEN (and only then) do I let them come out to the flightline so they can load up their baggage, ask questions about the plane, take pictures. etc. I also use this time to familize them with the door mechanisms, fire extinguisher location, fuel cutoff, how to transmit on guard, etc etc. Too many times I was interrupted (by both honest questions and by people wanting pictures before their first flight, etc.) and this has ensured I stay focused on preflight. This is my first post, BTW I look forward to moving from renting to owning an aircraft in the next 2-4 years, and it may just end up being a Mooney! -Dan 1
jeharlan Posted June 11, 2013 Report Posted June 11, 2013 I do GUMPS and I pump the breaks to make sure I have pressure on each pedal at 4 miles out and then for arrival into a non controlled airport on each leg of the pattern.
carusoam Posted June 11, 2013 Report Posted June 11, 2013 Have you ever lost brake pressure in the Eagle..? I'm thinking that the long bodies are too new for the typical issues of my (previous) M20C. Best regards, -a-
