I just noticed for the first time a spring-loaded pin with a hole in the middle protruding from the bottom of the left wing very near the wing root in my 68M20C. Forgot to check if there is a similar one under the right wing. What is it for? Tried to attach a picture but the upload failed, common problem in this new set up.
Yep... 99% that's what you're seeing... Static drain. Should have a second one, just past the wing more in the cener of the belly.
Yup, pitot static drain. You should push it to allow moisture to drain out every time you pre-flight. There may also be one on the underside of the fuselage, port side about half way back. Also check this during pre-flight.
Wow, talk about me not knowing something so basic/important. And this is my third Mooney! I just wonder what is the purpose of the hole through the pin. This must be in the preflight check but I don't remember ever seeing it.
Don't feel bad. I have had my plane for a little over three years. I found the drain under the wing right away, because it is in the manual. But just found out about the one under the fuselage a couple of weeks ago from Bruce Jaeger. You would never find it unless you knew to look for it.
I know that my plane has the drain at the port side wing root, but where is the one under the fuselage? Was it only included on certain model years?
While we're on this subject, in my 66E there is a leather pouch on the center pedestal containing a spoon with a v-shaped notch in it. It looks like it's been there a while. Any idea what THIS is for?
It's a spork
Could it be for switching tanks?
  • 1 month later...
At one of the Mooney Mapa Fly-ins I asked about that hole in the pin. I was told that it was there to hang a reminder banner so that you would see and remember to check it during your pre-flight. Sort of like the red banner hanging down from the pitot cover if you have one installed.
