hubcap Posted June 10, 2025 Report Posted June 10, 2025 Does anyone have a digital or hard copy of how to set up the fuel flows on a 231 with the TSIO-360-LB engine with the Merlin upper deck pressure controller and the Turbo Plus Intercooler? I know the system is pretty complex and there may even be tribal knowledge necessary. Thanks!
Z W Posted June 11, 2025 Report Posted June 11, 2025 Only guidance I know of is in SID97-3G, attached here, which is now a part of Continental's M0 I believe. When my fuel flows got all set wrong after a fuel pump replacement, nobody local could figure it out. Took it to Don Maxwell for annual and they dialed it in perfectly. I talked to them about it and they have some kind of a Bluetooth-connected pressure sensor that hooks up to an iPhone they use to set the pressures to spec. They knew to set the fuel flows a little higher at max power for better cooling. So, tribal knowledge is a good way to describe it. There may be even more of it for your Merlin/Turbo Plus setup. The fuel system setup procedure can be tedious. It has to be tested with the cowling on, so the cowling has to be removed, the settings changed, cowling reinstalled, then tested, then repeat as necessary until it's right. I suspect some shops lack the patience or time available. SID97-3G - Continuous Flow Fuel Injection Systems Adjustment Specs and Instructions.pdf 3
exM20K Posted June 11, 2025 Report Posted June 11, 2025 4 hours ago, Z W said: they have some kind of a Bluetooth-connected pressure sensor that hooks up to an iPhone they use to set the pressures to spec. That’s pretty slick, and a whole lot better than bringing hoses, gauges, and raw fuel into the cockpit. -dan
jlunseth Posted June 12, 2025 Report Posted June 12, 2025 (edited) The SID alone is not enough. There are instructions in the STC for the Turboplus. In very general terms, the Turboplus makes the induction air denser. There is a table in the STC instructions that tells the A&P what MP to use as max power during the setup procedure. It varies with OAT and is in the neighborhood of 36-37 inches. According to the STC instructions the A&P is to use the SID, but adjust the SID procedure per the STC. If you were to use the SID straight up you would use the factory MP setting of 40", which is way too high for an engine with an intercooler. I used to have the STC but don't think I have a copy any longer. You could contact Turboplus, they can send you one. It is somewhat difficult to get mechanics to understand the process and the importance of getting it right. They are fairly persistent in just defaulting to the SID. So the fuel flow is set to 24 GPH at 40" of MP, but you use let's say 36" as your full power setting because you have an intercooler and then what you see is insufficient fuel flow at full power which is actually 36", not 40. The fuel flow is supposed to be 22.5 - 24.0 at max, but most A&Ps, following just the SID, set the fuel flow wrong and you will see 19-21.5 at 36". The consequence is an inability to keep CHTs under 400+ in a climb, especially in the "high, hot" conditions out west. Many of us (231 flyers) try to get our A&P to set the fuel flow to about 25 GPH at max power (max power as defined in the STC table), which gives us a little extra fuel to work with in the summer. You could ask Paul Kortopates, he understands it pretty well. This means that on the ground you may want to reduce the fuel flow a little to stay under 24 during takeoff, but it sure helps with summer temps and climb outs. Edited June 13, 2025 by jlunseth 2
hubcap Posted June 12, 2025 Author Report Posted June 12, 2025 On 6/11/2025 at 5:28 AM, Z W said: Only guidance I know of is in SID97-3G, attached here, which is now a part of Continental's M0 I believe. When my fuel flows got all set wrong after a fuel pump replacement, nobody local could figure it out. Took it to Don Maxwell for annual and they dialed it in perfectly. I talked to them about it and they have some kind of a Bluetooth-connected pressure sensor that hooks up to an iPhone they use to set the pressures to spec. They knew to set the fuel flows a little higher at max power for better cooling. So, tribal knowledge is a good way to describe it. There may be even more of it for your Merlin/Turbo Plus setup. The fuel system setup procedure can be tedious. It has to be tested with the cowling on, so the cowling has to be removed, the settings changed, cowling reinstalled, then tested, then repeat as necessary until it's right. I suspect some shops lack the patience or time available. SID97-3G - Continuous Flow Fuel Injection Systems Adjustment Specs and Instructions.pdf 3.17 MB · 4 downloads Thank you for the information, but it doesn't cover the TSIO-360-LB engine. I believe that is for the engine in the 252 and Encore.
Z W Posted June 12, 2025 Report Posted June 12, 2025 The SID covers the TSIO-360-LB: Here are the adjustment specifications from the document for the LB and GB engines in a 231: I'd defer to what @jlunseth said about modifying it for your STC'd wastegate or intercooler. And I'd try to make sure your mechanic has access to the STC documents and any instructions in them. I also can confirm the drawings of the fuel pump and adjustment mechanism locations don't exactly match what are in my plane. But, I spent a lot of time on this a couple years ago and came to the conclusion this was all the factory / manufacturer guidance available. If anyone else has more I hope they'll post it here. Good luck.
hubcap Posted June 13, 2025 Author Report Posted June 13, 2025 16 hours ago, Z W said: The SID covers the TSIO-360-LB: Here are the adjustment specifications from the document for the LB and GB engines in a 231: I'd defer to what @jlunseth said about modifying it for your STC'd wastegate or intercooler. And I'd try to make sure your mechanic has access to the STC documents and any instructions in them. I also can confirm the drawings of the fuel pump and adjustment mechanism locations don't exactly match what are in my plane. But, I spent a lot of time on this a couple years ago and came to the conclusion this was all the factory / manufacturer guidance available. If anyone else has more I hope they'll post it here. Good luck. Thank you. Those are the correct numbers for the LB, but I believe there is a step by step process to set it up correctly that I need as well.
Fly Boomer Posted June 13, 2025 Report Posted June 13, 2025 7 minutes ago, hubcap said: Thank you. Those are the correct numbers for the LB, but I believe there is a step by step process to set it up correctly that I need as well. I think the SID is attached above.
jlunseth Posted June 17, 2025 Report Posted June 17, 2025 I did a search on my old posts and found the Turboplus instructions for setting fuel flow:TSIO360 Fuel Setup - NEW 08.pdf As I said earlier, some of us try to get the fuel flow set a little higher. Please note that the max power MP in these instructions will generally be higher than the 36-37" most of us use to set full power in flight. The fuel setting process is conducted on the ground with the aircraft not moving and therefore very little air is passing over the intercooler to cool the induction air. The intercooler becomes more efficient as the aircraft picks up speed during takeoff and flight, and air passes through the scoop and over the fins of the intercooler. At cruise at altitude it is not uncommon to see a differential temperature (Compressor Discharge Temperature minus Induction Air Temp) of 100-125 degrees. So the higher max power MP in the table in the instructions is not directly applicable to in-flight power settings. 1
hubcap Posted June 17, 2025 Author Report Posted June 17, 2025 2 hours ago, jlunseth said: I did a search on my old posts and found the Turboplus instructions for setting fuel flow:TSIO360 Fuel Setup - NEW 08.pdf As I said earlier, some of us try to get the fuel flow set a little higher. Please note that the max power MP in these instructions will generally be higher than the 36-37" most of us use to set full power in flight. The fuel setting process is conducted on the ground with the aircraft not moving and therefore very little air is passing over the intercooler to cool the induction air. The intercooler becomes more efficient as the aircraft picks up speed during takeoff and flight, and air passes through the scoop and over the fins of the intercooler. At cruise at altitude it is not uncommon to see a differential temperature (Compressor Discharge Temperature minus Induction Air Temp) of 100-125 degrees. So the higher max power MP in the table in the instructions is not directly applicable to in-flight power settings. Thank you sir. It seems there is a problem with my fuel pump........that was rebuilt a year or so ago. The fuel flow is fluctuating with the same MP setting.
jlunseth Posted June 18, 2025 Report Posted June 18, 2025 (edited) Well, it depends on how big the fluctuation is. I have had two engines with different fuel pumps and the fuel pump on the first engine was rebuilt back in about 2009 so that is three fuel pumps. All three behaved in basically the same way. When I fly LOP, very small changes in fuel flow will affect TIT, which is what I mainly watch. So it is not uncommon for the fuel flow to vary up and down a few tenths. And when I take a flight and set a LOP fuel flow it is also not uncommon for the fuel flow to increase by about .5 GPH or thereabouts, in the first ten or fifteen minutes, and for the MP to increase also. Probably this is because the aircraft is picking up speed and as it goes faster the ram air effect increases, and that increases MP which in turn increases fuel flow. I dial them down and after awhile the system finds and equilibrium. Remember that in the 231, fuel flow and manifold pressure are co-dependent, a change in one causes a change in the other. Now if your fuel flow variation is big, say 1 GPH or more, probably a fuel pump issue. But if it is relatively small the issue can be (1) the 231 MP and fuel flow control systems are inherently not that precise, or (2) there is an issue with the throttle control that in turn is reflected in changing fuel flows. Also, check the "waterwheel." That is the paddle wheel sensor that detects fuel flow and reports it to the engine monitor/display. I have had two of those wear out. You will see fairly large changes in fuel flow without significant changes in either MP or the temps that you would expect to see change if the fuel flow were actually fluctuating (EGTs and TIT). Relatively simple replacement. Best of luck, hope you can figure it out. Edited June 18, 2025 by jlunseth 1
hubcap Posted June 19, 2025 Author Report Posted June 19, 2025 What is happening is that when you set the MP to 34" sometimes you get a fuel flow of 24 GPH but then occasionally you only get 19 GPH with the same setting. Same with other MP settings, but I used that for the example in this case. The fuel pump was rebuilt a little over a year ago. Sent the fuel pump back to the guys that rebuilt it this week for their evaluation. They seem to think they know what is wrong with it. The MP setting doesn't give a reliable fuel flow at this point. Sometimes its correct and sometimes its not. It's not a gauge issue because the TIT temp matches the fuel flow on the gauge.
jlunseth Posted June 19, 2025 Report Posted June 19, 2025 Yes, if the TIT varies when the fuel flow varies it is a real issue as opposed to an instrument issue. I had one fuel pump rebuilt as I mentioned, it had to go back once for a similar issue to yours. Don't know who the vendor was, it was 15 years ago. Good luck. 1
hubcap Posted July 4, 2025 Author Report Posted July 4, 2025 On 6/19/2025 at 2:03 PM, jlunseth said: Yes, if the TIT varies when the fuel flow varies it is a real issue as opposed to an instrument issue. I had one fuel pump rebuilt as I mentioned, it had to go back once for a similar issue to yours. Don't know who the vendor was, it was 15 years ago. Good luck. Sent the fuel pump off and had it completely re-built. Spoke with the IA this morning. They installed the fuel pump but can’t get 24 GPH at 34” of MP. Increasing the pressure did not increase the fuel flow. Must be something else. He is going to make some calls on Monday.
Jim F Posted July 7, 2025 Report Posted July 7, 2025 What was the unmetered fuel pressure and EGT at 2700, & 34"MAP. The fuel metering unit (throttle body), flow divider, and nozzles are all that's left. When your mechanic increased the unmetered fuel pressure did you see any increase in fuel flow?
Will.iam Posted January 27 Report Posted January 27 On 7/4/2025 at 4:07 PM, hubcap said: Sent the fuel pump off and had it completely re-built. Spoke with the IA this morning. They installed the fuel pump but can’t get 24 GPH at 34” of MP. Increasing the pressure did not increase the fuel flow. Must be something else. He is going to make some calls on Monday. Out of curiosity did you ever find out what the problem was?
hubcap Posted January 27 Author Report Posted January 27 13 hours ago, Will.iam said: Out of curiosity did you ever find out what the problem was? Yes. When the fuel pump came back from the rebuild, one or more of the adjustments was completely out in left field. I don’t remember exactly what it was but they figured it out and it’s right on the money now. 1
kortopates Posted January 28 Report Posted January 28 Yes. When the fuel pump came back from the rebuild, one or more of the adjustments was completely out in left field. I don’t remember exactly what it was but they figured it out and it’s right on the money now.There are only two:Low pressure unmetered pressure for IdleHigh metered pressure for max powerWhen you change one it can throw off or alter the other. Setting up a Continental fuel flows requires iterating on adjusting these both till both are in spec. Sent from my iPhone using Tapatalk
MattSet Posted February 14 Report Posted February 14 Mine has a bad fuel pump. It was showing 5 gph lower then normal 19 gph at take off power. New one just came in and setting up flows now. Glad to have this read just in time.
