Matthew P Posted yesterday at 01:53 AM Report Posted yesterday at 01:53 AM are 5.00 - 5 6-ply tires larger in diameter than 5.00 x 5 4-ply..looking at retreads to keep on hand as spares, like the durability of 6-ply vs 4-ply but worried if larger diameter that there might be an issue in regarding to the front wheel well? TIA Matt Quote
Sabremech Posted yesterday at 02:50 AM Report Posted yesterday at 02:50 AM 56 minutes ago, Matthew P said: are 5.00 - 5 6-ply tires larger in diameter than 5.00 x 5 4-ply..looking at retreads to keep on hand as spares, like the durability of 6-ply vs 4-ply but worried if larger diameter that there might be an issue in regarding to the front wheel well? TIA Matt Look at the TCDS for which tire you can use. 2 Quote
PT20J Posted yesterday at 03:26 AM Report Posted yesterday at 03:26 AM 34 minutes ago, Sabremech said: Look at the TCDS for which tire you can use. THIS ^^^^^. Airplanes aren't like cars -- you can't legally just change parts without some sort of approved data. Quote
1980Mooney Posted yesterday at 03:46 AM Report Posted yesterday at 03:46 AM 1 hour ago, Matthew P said: are 5.00 - 5 6-ply tires larger in diameter than 5.00 x 5 4-ply..looking at retreads to keep on hand as spares, like the durability of 6-ply vs 4-ply but worried if larger diameter that there might be an issue in regarding to the front wheel well? TIA Matt Read the Goodyear or Michelin Aviation Tire Catalogs. Within a tire size such as 6.00 -6 or 5.00 - 5, the 6 ply and 4 ply have the same diameter and width. That way they fit properly within the wheel well. Retreads change the outside sizing. Data-Section-2022.pdf Aviation-Databook-2022.pdf https://dgaddcosprod.blob.core.windows.net/multisite-ds/clhaa3pb0002h01o7g7y69vf6/attachments/cli4jqcwj07dc01mogaxc24lx-csm-revf-june2021.pdf aviation-tire-care-2024.pdf Quote
Matthew P Posted yesterday at 04:22 AM Author Report Posted yesterday at 04:22 AM 34 minutes ago, 1980Mooney said: Read the Goodyear or Michelin Aviation Tire Catalogs. Within a tire size such as 6.00 -6 or 5.00 - 5, the 6 ply and 4 ply have the same diameter and width. That way they fit properly within the wheel well. Retreads change the outside sizing. Data-Section-2022.pdf Aviation-Databook-2022.pdf https://dgaddcosprod.blob.core.windows.net/multisite-ds/clhaa3pb0002h01o7g7y69vf6/attachments/cli4jqcwj07dc01mogaxc24lx-csm-revf-june2021.pdf aviation-tire-care-2024.pdf Thanks, so a retread that's a 5.00 x 5 4-ply retreat will probably be a larger diameter than a 5.00 x 5 4-ply non-retread? Quote
Andy95W Posted yesterday at 04:26 AM Report Posted yesterday at 04:26 AM Aviation Consumer magazine talks about tires on a regular basis. They’ve stated that to meet the TSO for tires, they must still be to the standard dimensions. But you probably still wouldn’t want to use them for a nose tire. Balance, older age, and quality could be concerns. At the flight school where I was a CFI and A&P, we put retreads on the mains but only brand new on the nose for those reasons. Quote
1980Mooney Posted yesterday at 05:32 AM Report Posted yesterday at 05:32 AM 1 hour ago, Matthew P said: Thanks, so a retread that's a 5.00 x 5 4-ply retreat will probably be a larger diameter than a 5.00 x 5 4-ply non-retread? I think so. Some are larger than others, i.e. Desser Monster Retreads Quote
Matthew P Posted yesterday at 01:46 PM Author Report Posted yesterday at 01:46 PM 1 hour ago, PT20J said: Thanks Quote
cliffy Posted 23 hours ago Report Posted 23 hours ago I have known of an FAA Inspector (many years ago) who dinged a plane with 6 ply on the nose and it not being in the TCDS I don't think today any current FAA type would even know that issue but why ring the bell? Quote
Matthew P Posted 21 hours ago Author Report Posted 21 hours ago 1 hour ago, cliffy said: I have known of an FAA Inspector (many years ago) who dinged a plane with 6 ply on the nose and it not being in the TCDS I don't think today any current FAA type would even know that issue but why ring the bell? Exactly, i was just looking from a durability standpoint, but 6-ply is a bit stiffer. Quote
N201MKTurbo Posted 21 hours ago Report Posted 21 hours ago Just an update on my Monster tires. They have been on there for quite a while. Almost 10 years. They still have tons of tread. After I ground 1/4 inch of tread off of them, they are great tires. I think they make a standard sized tire with the same rubber. Quote
