AJ88V Posted December 22, 2024 Report Posted December 22, 2024 Ran across this Mooney Retrofit Kits list https://mooney.com/wp-content/uploads/2020/12/Retrofit-Kits.pdf It's broken out with an applicability list ("AIRCRAFT EFFECTIVITY") Some look rather interesting, but there are no prices and some descriptions are sufficiently vague that it's hard for an owner to know if a particular retrofit is just a replacement fix or a potential upgrade to their aircraft. Sure, "if it ain't broke, don't fix it" is a pretty good axiom, but your experience with some of these kits might be helpful to the general community down the road. Suggested format: Aircraft model (-, A, B, C, D, E, F, G, J, K, M, etc.) Kit ID Details (what it did: repair/replacement, improvement) Kit cost (state year when you bought it) Kit install cost Thanks! Quote
PT20J Posted December 22, 2024 Report Posted December 22, 2024 These have to be purchased through a MSC and each MSC sets its own prices. Some are for service bulletins that should have been installed by now. Many are no longer available except by special order. Rudder pedal extensions are probably the most popular. Quote
AJ88V Posted December 22, 2024 Author Report Posted December 22, 2024 35 minutes ago, PT20J said: These have to be purchased through a MSC and each MSC sets its own prices. Some are for service bulletins that should have been installed by now. Many are no longer available except by special order. Rudder pedal extensions are probably the most popular. Rudder pedal extensions was how I found the Retrofits list. Not sure why I suddenly want these after many years of ownership, but.... Quote
PT20J Posted December 22, 2024 Report Posted December 22, 2024 1 hour ago, AJ88V said: Rudder pedal extensions was how I found the Retrofits list. Not sure why I suddenly want these after many years of ownership, but.... Well, if you do get the extensions, note that the 1.5" kit contains parts for both pedals, but the 3" kit contains parts for only one pedal so you have to order two. Quote
1980Mooney Posted December 22, 2024 Report Posted December 22, 2024 2 hours ago, AJ88V said: Ran across this Mooney Retrofit Kits list https://mooney.com/wp-content/uploads/2020/12/Retrofit-Kits.pdf It's broken out with an applicability list ("AIRCRAFT EFFECTIVITY") Some look rather interesting, but there are no prices and some descriptions are sufficiently vague that it's hard for an owner to know if a particular retrofit is just a replacement fix or a potential upgrade to their aircraft. Sure, "if it ain't broke, don't fix it" is a pretty good axiom, but your experience with some of these kits might be helpful to the general community down the road. Suggested format: Aircraft model (-, A, B, C, D, E, F, G, J, K, M, etc.) Kit ID Details (what it did: repair/replacement, improvement) Kit cost (state year when you bought it) Kit install cost Thanks! Notice that the list includes Vertically Adjusting Pilot/Copilot Seats and Electric Standby Vacuum System retrofits - neither still sold. The list probably has not been updated in ages. 1 Quote
Fly Boomer Posted December 23, 2024 Report Posted December 23, 2024 6 hours ago, AJ88V said: Rudder pedal extensions was how I found the Retrofits list. Not sure why I suddenly want these after many years of ownership, but.... And search MooneySpace for pictures so you can determine what you have now. Quote
