Hi, I couple of months ago I did some cosmetic maintenance on my front landing gear doors and replaced the anti-chafing tape (one that was white and looked made of a material similar to fiber glass) with a black 3M tape that is supposed to be the correct one, but after the last flight I notice that it was kind of "burnt", as when you expose a tape to high temp and it shrinks/wrinkles.
I'm quite sure that this was to not handling the friction between the parts well.
Which is the best anti-chafing tape I could use? I'd like to find out what is the brand of the white one I used to have.
Your best option is 1/16" rubber sheeting material held in place by 3M 1300L Super Weather Stripping Adhesive (NOT the General-Purpose stuff).  You want 3/4" wide strips to be cut evenly and then shaped with an XActo or other blade to the contour of the gear doors.  I can send you some of the material sufficient to do the job if you want...PM me for details if interested  Just pay me for shipping.  I have excess.
Steve
3M makes a white/clear HD PTFE tape designed for this.  It's expensive .  Scotch makes an "equivalent " product that is considerably cheaper.   I bought the Scotch brand and it's holding up well.
Do you happen to have the Scotch product code? I tried to find it and I couldn't.
Looking at the prices on Amazon, the 3M stuff is ridiculous.   I got this Scotch brand stuff for 80% less.  I don't suppose you'd need more than a few short pieces.  If so, PM me how many strips you need, how long, plus your address and I'll mail it to you free.
Thanks all for all the info and especially to @0TreeLemur and @StevenL757 for kindly offering to ship some tapes for free! I will get some UHMW generic tape and see how it goes.
Owning a Mooney is not just owning the best GA airplane (at least the best value you can get!), but also being part of the best GA community!
I have had really good luck with putting 1/2" wide TapeCase 200A silicone foam tape on the doors and putting TapeCase 1" wide 423-3 UHMW tape on the belly. Both are available from Amazon. Both have really good adhesive but can be easily removed.
TapeCase 1" wide 423-3 UHMW is the one I got, I hope it works well.
  • 1 year later...
Sorry to revive this thread, but has anyone used rubber like stated above? I have a lot of 1mm Goodyear and would like to use it but don't k ow if it will be too thick. Anyone have any pics or experience with that method?
