I am, unfortunately, going to be forced into a panel upgrade, rather than just installing 3x GI-275s. I am taking the opportunity to consider swapping out my switches from the hard to find Klixon Rocker Switch to something more readily available and cheaper. Talking to Don Maxwell's parts folks, they have or can get the new Mooney style switches. These are the Carling Contura V switches (https://www.carlingtech.com/sites/default/files/documents/V-Series_datasheet.pdf). However, these are a lot bigger than our Mooney ones. Curious what others have done here. I am considering using Cirrus parts like this switch: https://baspartsales.com/53074-001-cirrus-sr22t-rocker-switch-fuel-boost-pump-volts-28-hours-695-5/.
New avionics shop would be okay with FAA/PMA parts I am guessing.
Thoughts?
Thoughts?
There are a number of modern options these days and many have upgraded switches during panel refreshes.    Many of the Mooney switches are breaker switches, where the switch is also the circuit breaker, so be sure to replace those with either another breaker switch or a switch and a new separate circuit breaker.
Would love to see the options :-)
Yep, I was planning for it. Since I am getting a new panel and removing the engine instruments on that side, will have room to add more CBs and redo the layout.
Shawn
Why?  How is one forced into such a decision?
Alex
I am in the middle of a major panel upgrade.  I am going with toggle switches.  Only rocker switches will be the ElectroAire mag switch/push button starter panel.
The only thing to note is, the breaker switches will have the breaker amperage on the tip of the toggle and the others will be rounded.
Also using the time to group and layout the switches.  So lighting switches will be together, with the most used to the end of the row that is most convenient.
For mine, lighting will be to the right, engine and such (boost pump, avionics, master, alternator, etc) will be to the left.
Another search landed me on https://sps-support.honeywell.com/s/article/AST-Does-Honeywell-offer-a-FAA-PMA-1-pole-off-on-Lighted-Rocker-Switch which cites Honeywell offers FAA/PMA switches:
Datasheet: https://prod-edam.honeywell.com/content/dam/honeywell-edam/sps/siot/ja/products/switches/rocker-switches/tp-series/documents/sps-siot-micro-switch-tp-rocker-product-sheet-005438-1-en-ciid-176934.pdf
Interesting tidbit on why a switch is PMA and why one isn't:
The AML24 series Rocker switch part numbers: AML24GBE2CA03-001 and
p/n: AML24GBE2CA03 are the exact same switches with the same specifications and functionality.
The only difference is that the part number: AML24GBE2CA03-001 has the brand Customer p/n on the housing and it is FAA-PMA approved.
The regular part number: AML24GBE2CA03 does not have that brand Customer p/n on the housing and it is not FAA-PMA approved, so as long as the switch is not used for aerospace applications it should be fine since the regular AML24GBE2CA03 would not be FAA-PMA approved but of course is UL / CSA certified as all products have to be.
Source: https://sps-support.honeywell.com/s/article/AST-What-is-the-difference-between-the-AML24-Series-switch-part-numbers-AML24GBE2CA03-001-and-AML24GBE2CA03
