Went up today to fly for a bit.  On takeoff, I noticed the oil temp was a tad high but it wasn't bad. Around 180 IIRC.  Once I got to about 5500, I noticed the temp was at redline.  I backed the MP/RPM back to 24/24 and kept it at full rich mixture.  Cowl flaps remained open.  The oil temp came down to about 240 but wouldn't go below that.  Even backing MP down to 20" it stayed close to redline.  Normally, I see temp around 160-170, don't remember it ever being over 180, especially in cruise.
Where do I start with troubleshooting?
Was your oil pressure different than it normally is?
Oil pressure was top of green arc on takeoff. By the time it got to altitude it had dropped to about 74. Which is about normal.
Oil temp was normal at run up, about 120.
CHT was normal as was EGT. I only have single probes for CHT/EGT though.
If your oil pressure is normal but the temp is at levels you indicate would check the temp probe.  Oil temp of 240 is going to degrade pressure.
As @hammdo said, temp that high should make a noticeable decrease in pressure.  Id check the probe.
Put the probe in boiling water and see what the temp shows.
Ground it with an alligator clip wire you make up.
Check it cold- check it hot using an IR temp gun.
Having just gone through an issue with faulty reading, I don’t think the thermocouple has failed, but worth checking. Problems can be caused by maintenance, but they are normally binary (it works or it doesn’t).  I cannot envision a maintenance induced issue that causes it to read 60° high.
I would expect increased oil burn at those temps and a decrease in oil pressure. No chance that you winterized the cooler earlier in the season and then went flying on an unseasonably warm winter day?
Oil pressure may have been a couple psi lower but still within normal range for what I typically see. Oil pressure was about 74-75 and I typically see just below 80.
No winterization.
The oil temperature needle was kinda bouncing off redline, from about 230-250 from what I recall.
Grant just had a new panel installed, so that could have tweaked something….
-Don
Yeah I’m gonna go check the oil temp probe and the connections to the indicator this afternoon.
I got a full panel done so I agree and think the most likely scenario would be the connection to the indicator since the whole cluster was removed and reinstalled.
Went to the airport today and the oil temp was showing 150 after sitting for over 24 hours.  Obviously oil temp wasn't that high in reality.
Tapped on the housing of the indicator (not on the glass) and the reading came down to about 80.  Ambient temps today are around 60.
Should I send it off to have it overhauled or should I fly it and see what happens?
If send for overhaul, who should I send it too?  Looks like Rudy's also overhauls Oil temp gauges, I'll give them a call but open to other recommendations.
Looks to me like the part number is 169C-910-11?? Looks like there is or used to be another digit/character to the left of the C maybe?
Edited by gwav8or
A few years ago, another MooneySpacer was selling the following, so I suspect your number is correct:
CHT Cluster Gauge            Garwin 169C-910-12
Oil Temp Cluster Gauge       Garwin 169C-910-11
Oil Pressure Cluster Gauge   Garwin 169C-914-1
Cluster Gauge Box            Garwin 22-169
L & R Fuel Gauges            Garwin 169C-910-28 1 and 2
There is a place in Lock Have PA that also overhauls them In fact 2 places there.
You're lucky you have the six individual units Each ca be overhauled separately and not as a 6 pac for the early ones.
There is also replacement units new available from several suppliers
I looked around for replacement units but couldn’t find them. Can you share a source?
  • 2 weeks later...
Well crapola as my dad used to say.
I sent my oil temp indicator to Rudy Aircraft Instruments and they called me Tuesday to let me know that it is too far gone and can't be overhauled.
So, I'm now earnestly searching for a replacement for a Garwin 169C-910-11.
I called Mitchell Products and the sales guy that I talked too and gave the above part number too gave me their part number that he said would replace my indicator.  Unfortunately, he didn't seem to know what he was talking about.  The Garwin gauges are modular and square and the replacement part number he gave me wasn't even close to being a replacement.
So if anybody has a Garwin 169C-910-11 laying around, let me know?
1 hour ago, Shadrach said:
Yeah, those look to be the same as the one I have and I'll look into getting one of them.  However, my concern is that the one I pulled out of my plane is a Garwin 169C-910-11 and all the ones I've seen at LASAR, BAS, salvage places, etc are Garwin 169D-910-11.  I'm not sure of the difference between the "C" variant and the "D" variant and if there would be any compatibility issues.  While I'd absolutely love to go ahead and put in the JPI 900 that I plan on doing later in the year, I just dropped $$ on a panel upgrade and I'm not sure if my CFO (wife,  aka better 2/3) would be too positive toward spending the extra $$ right now lol.
I have one I pulled out of my '89 M20M last year. I'm headed out to the hangar in a bit and will look at the model number and let you know.
Cheers,
Junkman
Cheers,
Junkmn
Awesome, thank you!
Yours looks like there is a D preceding the C.
Texas Air Salvage. They have several vintage Mooneys in their parts donar inventory.
Awesome, thank you!
My bad, my removed gauges are the cluster type. I thought I might be able to remove the oil temp gauge from the cluster block but no luck so far.
Not so many cheers,
Junkman
