I've had my 2000 Bravo for 2 months. In order to close the cabin door you have to pull down on it for the top front  stationary pin to fit into the hole. Is this normal or should I have the door re-rigged.
 Alan
 N9127M
It will be the effect of being slammed shut a few times. get it adjusted and always brief pax that you will secure the door. Did I mention groping is allowed in your own plane :)
 Alan
 N9127M
https://www.aircraftspruce.com/catalog/cspages/warningonlythepilotplacard.php?clickkey=6452
I have this just below the door handle and during the pre-flight briefing explain some of the horrible things that could happen to passengers that touch the door handle, or god forbid, slam the door . (Killing, maiming, losing a limb, etc . . . With me inflicting any of those . . . .  at my option)
Then I have another placard above the door saying DO NOT SLAM DOOR.
The pre-landing briefing includes a briefing about when we are coming in to land and are below 1000 feet - just two very simple rules, easy to remember:
1. The Golden Rule: Silence is Golden
If for some reason Rule number one doesn't work, then we have the 2nd rule as a backup. . .
2. The Silver Rule: Duct Tape is Silver
I suppose you could follow up with, "Which is better . .  Gold or Silver?
